Results 1 to 26 of 26
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    Test pipe instal Q
    Im picking up my test pipe today and installing it tonight.
    Any tips for removing the stock cat? My car has 60k on it.
    Buncha motorcycles
    Memphis, TN
    Re: Test pipe instal Q
    presoak all the bolts with PB blaster or something of the sort a few hours in advance
    have plenty of extensions in various lengths as well as some flex head sockets.
    also start drinking at least 1 hour in advance to numb some of the pain. also a drinking buddy will be useful holding stuff for you and handing you beers as you curse under the car
    APR Stage 2/AWE Intake
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    gloves and lots of beer.
    a DIY might be a good idea too. the bolts can be a bitch to reach... i couldn't get mine off and just ended up cutting the downpipe in half from under the car and pulled it all out as one unit, but i was replacing everything anyway so i didn't care that i cut the downpipe.
    Check this out, it's all done from under the car, looks pretty easy compared to doing it from the top (which i think you have to do if you have a tiptronic or cvt since the transmissions are larger and you don't have as much room to pull the cat out, so it has to be done from the top).
    http://www.audizine.com/forum/showth...t=testpipe+diy
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    As Chris said BEER
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Just make sure the socket has a GOOD grab on the nuts....you dont want to strip them
    -Sami-
    Buncha motorcycles
    Memphis, TN
    yes, if you strip something, you will then
    i would only use 6 point sockets on them. 12s can strip too easy
    Established Member Two Rings dmott11's Avatar
    Jan 28 2008
    MA.USA
    yeah, youll need that too.
    "slow is smooth and smooth is fast"
    Veteran Member Four Rings trueno429's Avatar
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    12 point is better than 6 point
    Dec 18 2007
    nj
    12 point is more likely to strip the nut since it's not conforming to the nut as much as the 6 point would., the 6 point simply has more surface contact, think about it.
    Established Member Two Rings ExCarpi's Avatar
    Apr 06 2008
    2005 A4 1.8T 6sp
    Minneapolis, MN
    Skip the 6 point and go straight for the torch!
    The bolts at the turbo are pretty easy but the others are a B**CH!
    APR TIP, APR 1+, TT injectors, RaceTec FMIC, JHM Extra short throw shifter (45% reduction), ER Test Pipe, 19" OZ Ultraleggeras, B5S4 Front Calipers, Adam's Rotors with black hubs, Hawk HPS, PSS9 coilovers, Hotchkis Sways, clear corners, tint, Magnaflow Exhaust, Podi pod with SW boost gauge.
    Established Member Two Rings smarrick's Avatar
    Apr 07 2008
    04 A4 18T 6MT QT SPORT, 07 X3, 74 Lincoln Continental
    Fort Collins, CO
    Quote Originally Posted by trueno429 View Post
    Ummm NO! 6 point is for 6 point 12 point is for 12 point. Yes 12 will work on 6 but not as secure.
    Fort Collins Drinking Team Member #2
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by ExCarpi View Post
    thats the best advice yet!
    snap on has some great new six points sockets that grab on the sides not the corners of the nut.
    Nov 25 2007
    Do you mean heat them up?
    Iv heard quite a few horror stories about taking out the cat.
    12 case already purchased (Thats a given)
    Buncha motorcycles
    Memphis, TN
    some can be really stuck, others come of "fairly" easy with a little lubricant and muscle
    what mods do you have now? it would be great if you could do a vag com log of before and after with EGTs and boost! also another one of the car cooling down before and after the TP.
    Nov 25 2007
    Mods at the moment are Vag-com, podi boost gauge and a ecode FMIC.
    Picking up my injectors and TP after school today. Im planning on getting it chipped on the way home.
    Let me know what you want logged and ill post it up. I have to drive about 75km's to pick up the parts.
    Buncha motorcycles
    Memphis, TN
    it would be good to see logs of your EGTs and boost before the test pipe install and then again after you do it. cats hold a lot of heat.
    do it after you get flashed!
    Nov 25 2007
    Quote Originally Posted by Papachristou View Post
    Ok, Ill do a log of egt's/boost before and after getting chipped, then with the test pipe. What channels should i log?
    Apr 06 2008
    2005 A4 1.8T 6sp
    Minneapolis, MN
    Quote Originally Posted by Trev View Post
    No, I couldn't get the get bolts out at the end of the cat so I used a oxyacetylene cutting torch on the bolts. Then used a punch and they fell out. It was WAY easier! Just don't cut your exhaust. When it was all said and done, you couldn't even tell I used the torch.
    It took about 10 minutes for all of them with the torch. As I recall it took 12 hours of PB blaster and crushed knuckles before using the torch. (OK, maybe more like 45 minutes but I was getting impatient)
    Nov 25 2007
    Hmmmm i have a plasma cutter..... Might just see if i can use that
    Apr 06 2008
    2005 A4 1.8T 6sp
    Minneapolis, MN
    Just make sure to block the back side with metal plates and wear a good jacket.
    Things went a lot smoother!
    Senior Member Two Rings kbasham03's Avatar
    Sep 07 2008
    02 a4 1.8tqm, 91 Talon Tsi AWD
    Streamwood, Il
    I used a saws- all and cut through the bolts as far as I could then took a BFH and a chisel and broke the bolts off. For sure have at least a 12 pack, gloves, lots of extensions, swivels, a breaker bar and be prepared to swear like a truck driver. If you're doing it without a lift (jackstands or Ramps,) be prepared for your arms, hands, and neck to cramp like hell. Oh, and Have Fun!
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    most people say its an hour job...but seriously this job is such a PITA> I was so glad I went to a tuner shop and got it installed for a $100 because the TP actually wasnt a direct fit and the shop did a lil bit of machining to get things to work
    another stereotypical Audi
    Nov 25 2007
    Couldn't get it Vaged. I cant seem to keep the vag-com connected.... It connects then a min later it loses it's connection and i have to reconnect.
    Dec 18 2007
    nj
    ebay cable huh?
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    whatever, i was told in auto class in h.s that the 12 point was always better than the 6..and it seemed that way when we worked
    Nov 25 2007
    Quote Originally Posted by widgget View Post
    ebay cable huh?
    Nope Ross tech. I just got a email back from them. They say the cable is faulty and needs to be replaced...
