Results 1 to 15 of 15
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    what heat wrap to buy for downpipes?
    i want ot wrap my downpipes before they go back in my car, whats the best type to get? links? how much do i need to buy, for both pipes from the turbos to the oil pan.
    Veteran Member Three Rings awdbiturbo's Avatar
    Apr 20 2004
    01.5 S4 /95.5 URS6/72 914/
    Boston
    Re: what heat wrap to buy for downpipes?
    Quote Originally Posted by infinkc View Post
    dei one whole package...
    2001 Audi S4 Stage 3+/996TT with mods/HURACAN LP610-4 VORSTEINER NOVITEC VF ENGINEERING / 22 AUDI RSQ8 NARDO CARBON/22 RS6 NARDO BLACK OPTICS IE EVENTURI CTS
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 10 2007
    Why not add a heat reducing coating over the pipes?
    Veteran Member Three Rings fatezero's Avatar
    Feb 12 2004
    Orange County, CA
    DON"T BUY HEAT WRAP!
    It is very dangerous in a street car to run header wrap. Any debris, oil, liquids will imbed into the tape, and not have a place to escape and could cause a fire hazard. Also, moisture gets trapped and eats away at the exhaust.
    Spend the xtra $$ and do it right and get them heat-coated at a place like HP Coatings:
    http://hpcoatings.com/products/heat.aspx#E
    2021 C8 RS6
    2001 S4 Avant 3L Tial 770
    2004 Allroad 6spd EPL Stg 3 SOLD
    2001.5 S4 Avant AWE/GIAC Stg 3 SOLD
    2011 S4 6spd Suzuka Grey Pearl with GIAC Stg 1 SOLD
    2006 S4 Avant SOLD
    2001.5 A4 Avant K04/Jeff Moss Hammer File SOLD
    2001 Porsche 996 Turbo - SOLD
    2001.5 S4 AMS Stg 3 - SOLD
    Veteran Member Three Rings GetAudiHere's Avatar
    Mar 06 2006
    Minnesota
    How beneficial is the heat coating compared to just putting the dp's back in with the heat shields?
    Also how much approx. would it cost to heat coat both downpipes?
    Feb 12 2004
    Orange County, CA
    I have no idea why you want it? Keep the heat down in the engine bay?
    I am Stg 3 running FI Widemouths and I have no heat issues at all. Spend the $$ on a set of ER or AWE IC's. That was the best thing I ever did to combat heat. Oil and water temps went down noticeably
    2021 C8 RS6
    2006 S4 Avant SOLD
    Veteran Member Three Rings gmann's Avatar
    Jan 12 2008
    illegals and moonshine stills
    Under busted VW's/Audis, OH
    Quote Originally Posted by fatezero View Post
    Keeping heat in the exhaust DOES keep under hood temperatures lower, but at the same time it helps the turbo's along with combustion.........
    Join the OhioVW facebook group for gtg, show, and cruise instant updates!
    1998 VW Jetta GLX VR6 | 2001.5 Audi S4 6MT | 1984 VW Jetta GLi | 2004 VW Golf .:R32 | 2001 Audi TT 225 Coupe quattro
    Aug 06 2008
    Canadia
    just go to a local performance store and buy some, its usually pricey, but at least eveything under your hood won't get cooked.
    heat wrap isn't water tight so it can't trap in moisture and corrode your exhaust (which is made out of stainless steel BTW)
    as far as catching fire, that sounds like an old wifes tale, the flash point of engine oil is much higher than that temp of that downpipe.
    Feb 12 2004
    Orange County, CA
    Yeah, your right. It's all a "wives tale". It's just all made up facts.
    2021 C8 RS6
    2006 S4 Avant SOLD
    Aug 06 2008
    Canadia
    logically the rusting out makes no sense.
    Feb 12 2004
    Orange County, CA
    Hey, not my car so be my guest and try it out. I have been there and done that with prior cars and it ain't a good thing for a "daily driver".
    2021 C8 RS6
    2006 S4 Avant SOLD
    Jan 12 2008
    Quote Originally Posted by MacDaddy View Post
    Uh.... Engine oil collects gasoline in it, gasoline has a lower flash point than the oil that it's in. You only collect gas in your oil when you're car is running rich, and none of our cars run rich. We like them super lean so we can get good fuel economy
    J/k. It can happen though. I've seen DSM's light up because of it, and DSM's have a crap ton of room in their engine bay for air to circulate and fumes to evaporate a lot more than an S4 engine bay.
    Aug 06 2008
    Canadia
    Quote Originally Posted by gmann View Post
    I can see it being an issue there where you ignore an oil leak, and you are either running rich and/or not changing your oil very often. but I figure hes taken care of timing chain tentioner and camshaft seal leaks if he wants to go out and drop a few hundred on some heat tape.
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    If you have piggies then you dont have to worry about heat under the hood. I have piggies without the heatshields and my underhood temps are lower than stock dp's w/shields. About a month ago i ran it hard while racing a 350z...and after 8 races i was able to hold my hand a few inches away from the DP without getting burnt.
    Heat wrap has been known to cause more damage than help. Some have used it for a LONG time without any problems. Personally, i wouldnt use it again. I would just use some ceramic based high temp paint and call it a day. The paint probably wont do much, but it wont hurt and its only $5 so you might as well try it while you have to dp's out lol.
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Jan 12 2008
    Quote Originally Posted by sCeRaXn View Post
    its only $5
    It's a LOT more than $5.
    But I see what you're saying MacDaddy, but the possibility is out there that a turbo oil like could leak, or anything. And that's a risk to take when you could just get them ceramic painted.
