    Apr 28 2008
    Londonderry, VT
    s4 extended lug bolts
    I jus got two new 19" rs4 replica wheels for my stage 3 to match the back but they seem to be a bit wider. Where can I find bolts 1/4" longer or so to fit my audi? Any help would be appreciated. Thanks
    Ian
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Re: s4 extended lug bolts
    ECS sells bolts , you just have to figure out the inch to MM comvertion, Good luck, any snow up in VT yet?
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Apr 28 2008
    Londonderry, VT
    thanks. and yeah, there is about an inch on the ground and the wind is blowing.
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    outstanding I hope to be able to ride up there soon :)
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    i dont understand why people arent running on wheel studs. they are better and easier change wheels, and you dont have to worrk about different length bolts
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
