Results 1 to 6 of 6
    Registered Member Two Rings njjack2's Avatar
    Oct 16 2008
    2000 Audi A4, 2001 Lexus Gs300
    Tallahassee, Florida
    Front Diff on 2.8l B5 Auto
    So I recently noticed a leak coming form the front passenger axle seal. I ordered the seal and replaced it. Filled up the diff with gear oil, apparently it didn't have much in it because I put almost a quart in and it only holds .8 quarts. Now I get a roaring noise. Does anyone have or know of any instructions online to rebuild the center diff? I'm assuming it was out of fluid for a bit and toasted the gears or something internal.
    Aug 06 2008
    Canadia
    Re: Front Diff on 2.8l B5 Auto
    what kinda oil did you put in there?
    Oct 16 2008
    Mobil 1 75W-90.
    Aug 06 2008
    Canadia
    not sure then, you may have made an error when replacing the seal.
    rebuilding a differential isn't easy (been there), and will most likeley require removing the tranny. all i can say is double check everything you did for any loose bolts, etc.
    the B5 S4 is like the mafia... there is only one way out!
    Oct 16 2008
    Sounds good, As soon as I can get it back on the lift I'll check it out. Hopefully this weekend.
    May 16 2008
    South Texas
    Quote Originally Posted by njjack2 View Post
    Updates?
