Results 1 to 2 of 2
    Aug 06 2008
    Canadia
    cure for the shudder noise around corners...
    I decided to finally change out my center diff fluid a couple days ago, and i wish i did it sooner.
    since i've had my car, after its warmed up and i was turning somewhere tight like a parking lot i would get that vibration/shudder noise like the 4wd system was binding. I didn't feel anything so i figured the fluid was low or the anti-chatter additives were ineffective after 8 years of use (turned out to be the latter). I found an oil spec sheet for a 4-motion passat stating to use 80w-90 dinosaur oil, so i finally knew what oil to get after being told all kinds of tall tales.
    Anyway, i upgraded and replaced it with Redline 75W-90 (not 75W-90NS) gear oil, it was fairly straight forward, i was able to get at the fill plug with my hex socket on the end of my 3/8 ratchet, but to access the drain plug i had to unscrew the oxygen sensor. after the fluid was drained i used my suction gun to fill it back up.
    in total it took about an hour including jacking up the car.
    Registered Member Two Rings njjack2's Avatar
    Oct 16 2008
    2000 Audi A4, 2001 Lexus Gs300
    Tallahassee, Florida
    Re: cure for the shudder noise around corners...
    Thanks for posting....I guess I will be doing that this weekend.
