Results 1 to 9 of 9
    Oct 27 2006
    Pearl 98.5 Audi A4 1.8T
    Fargo, ND
    White smoke and black tailpipes
    I was told by a coworker today that my car has been putting out large amounts of white smoke/exhaust when I leave work.
    Also my tail pipes have a jet black residue on them
    not low on antifreze
    Any idea's
    1998.5 1.8TQT (SOLD)
    Joined the Dark Side
    2008 Honda Pilot SE
    Veteran Member Three Rings calvin1.8t's Avatar
    Oct 21 2008
    Mk3 vr6
    New Jersey
    Re: White smoke and black tailpipes
    the jet black residue might just be the condensation mixing with the carbon deposits. as for the smoke could be burning oil or mabey your cat is not working well.
    Oct 27 2006
    Fargo, ND
    Bump to the top - any other idea's
    2008 Honda Pilot SE
    Veteran Member Three Rings xraycer2012's Avatar
    May 28 2008
    B8.5 S4
    White smoke can also mean your burning coolant, check your coolant level. You might need a new head gasket. It could be leaking coolant into the cylinders.
    ‘23 RS6
    '14 S4 Nogaro Special Edition - Sold
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Damnit.....my car is doing this too.....I was trying to convince myself that it wasn't the head gasket, even tho i KNOW it is.......open the hood and look behind the engine, and see if there are any oil or coolant spills on the top of your tranmission. That could be a result of coolant and oil leaking out of the gasket
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Veteran Member Three Rings oldblu's Avatar
    Jan 01 2008
    Budd Lake, NJ
    ^ If you have the 2.8, where should you look for evidence that it's the the head gaskets?
    --Silver 2000 A4 2.8L V6 Quattro
    S4 Bumper. Borbet Type LS Wheels. M3 Replica Spoiler
    Blue! How come there's no ice
    in my lemonade?
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    It has been pretty cold around here the last few days. You sure it's not just the exhaust due to that.
    Oct 27 2006
    Fargo, ND
    Quote Originally Posted by generik777 View Post
    No this is over a couple weeks when it back in the 70's.
    And as for coolant, as I said in the OP Antifreeze is not low.
    Turbo going??
    2008 Honda Pilot SE
    Sep 16 2006
    '98 528i
    Could be the turbo....depends on how much smoke ur spewing out of there.....a few weeks ago, when my BT went, I noticed a substantial amount of white smoke (more than usual, considering I don't have a cat) and it was in the 70s out.....If it IS ur turbo, then that means that ur oil seals in the turbo are likely gone....so check ur oil level frequently, and keep a mental log of it over the span on a few days (it might be hard to tell, but give it a shot). If you notice it going down slightly, then it could be ur turbo.....OR it could still be that headgasket, since oil could potentially leak from there too
