Results 1 to 14 of 14
    Veteran Member Three Rings dpatel's Avatar
    Oct 03 2005
    Atlanta, GA
    Codes with 3.0 S/C
    Went WOT in 3rd the other day after 30 minutes of driving and it was 60deg out. Got the infamous blinking check engine light. I suspect I'm running lean. Finally got my Vag. Codes pulled are:
    5 Faults Found:
    17538 - Fuel Trim; Bank 2 (Mult): System too Lean
    P1130 - 001 - Upper Limit Exceeded - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - Upper Limit Exceeded
    16688 - Cylinder 4: Misfire Detected
    P0304 - 001 - Upper Limit Exceeded - Intermittent
    16685 - Cylinder 1: Misfire Detected
    P0301 - 001 - Upper Limit Exceeded
    16687 - Cylinder 3: Misfire Detected
    P0303 - 001 - Upper Limit Exceeded
    Even had a code on the tranny:
    17095 - Transmission Fluid Temp Sensor (G93): Implausible Signal
    P0711 - 003 - Mechanical Failure - Intermittent
    So what could be causing me to run lean up top. Car idle and runs fine.
    Also how do I check the long term fuel trim values?? Do I look at block 032 with the car off?
    - 3.0 Quattro
    - Milltek Exhaust with 4" Tips
    - Hyperflow Intake
    - Caracter Front bumper
    - Eibach Pro Kit + Bilstein Sport Shocks and S4 Rear Sway
    - Sportec 18" wheels
    - Stoptech Slotted Rotors with Ceramic Pads
    - Level 10 VB & APR Snub Mount
    - G3 SuPeRcHaRgEr
    VP of 3.0 CLuB
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    Re: Codes with 3.0 S/C
    i would guess the multiple misfires could cause you to run lean.
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Sep 23 2006
    Houston TX
    you can check 032 with the car running, also might as well look as 031 to look at your lambda values. What RPM range did the misfires occur? Hard to get much from lambda values without going WOT though which you obviously don't want to do. 032 might not be that useful though unless you have older logs to compare to. did you check your plugs? if you're familiar with engine sounds with the hood up you could try to listen for leaks. when was the fuel filter last replaced?
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    wait for me
    I am going to get tuning so that will be available for everyone.
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Quote Originally Posted by Maverick View Post
    wait for me
    He has GIAC tuning and has run the car hard in the past with no problems. So that points to a mechanical issue. Might be a coil pack or a fouled plug. Not sure about the transmission code. Could just be the sensor going bad.
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    I thought dpatel had the new update from PES i might be mistaken though
    May 03 2007
    german
    heaven/hell
    Quote Originally Posted by skeeball View Post
    I know that. maybe he can get better software for some more power.
    Oct 03 2005
    Atlanta, GA
    Car misfired after I changed gears from 3rd at redline to 4th and then let off the gas. How do you guys handle going WOT and then letting off the gass without the car bucking (since we don't have a blow off valve for the boost)???
    I have the GIAC tune. I'll do a log run to 5K this weekend (I'm still new with this VAG). Car ran great today. I kept it under 4Krpm though.
    I think my plugs might be going bad. I have had them for almost 20K. How often should I change them??
    I changed the fuel filter 20K ago also. It could also be a fuel pump issue as these fuel pumps are known to go bad.
    Is there away to check boost with VAG-COM??
    Let's all work together to get through this and help each other out!!!!
    - 3.0 Quattro
    - Hyperflow Intake
    - G3 SuPeRcHaRgEr
    VP of 3.0 CLuB
    Veteran Member Three Rings RASTA4's Avatar
    Feb 26 2005
    2002 A4 3.0
    Metro Detroit
    Plugs are a good start w/ the current ones @ 20k+. which might address the misfires. Not sure about the lean conditions....maybe check the surrounding vacuum lines for leaks. What FPR are you using? (3 or 4 bar).
    |2002 3.0 SEDAN Q6MT|POLAR WHITE|PLATINUM BUFFALINO|SPORT|CONVENIENCE|COLD|BOSE|BNS-NAV|PARKTRONIC|SUNSHADES|ODO=34XXX|
    MODS
    |PES G3 SC|SUPERSPRINT|AFE PRO-DRY|18x8 BBS RE-G FORCE SPORT|17x8 BBS RC-CONTIEXTREME|H-SPORT S4 SWAYS|AMS SS|APR SNUB|STOPTECH 332 FRONT-BREMBO X-DRILLED REAR|HAWK HPS|SS LINES|OPTIMA-REDTOP35|XENON ECODES|LED CITYLIGHTS|HOEN|SYMPHONY II+|DICE|35% SOLAR GARD|S4 DOOR FLARES|MOTUL 5.1|MOBIL 1 0W40|
    May 03 2007
    german
    heaven/hell
    i think most people are running 4 bar FPR
    Sep 23 2006
    Houston TX
    I'd bet money its your plugs. 20k is slightly early to be changing platinums but our cars have to run rich (more rich than stock) to keep temps down so that causes carbon buildup on the electrodes. Especially with colder weather here, though obviously Atlanta isn't what I would call cold yet.
    Sep 23 2006
    Houston TX
    post a picture of what they (plugs) look like. also you might want to switch to coppers and change them more often. I actually found my car ran better with some cheap NGK coppers than the OEM plugs. You have to replace them every 5k or so but they're only $2-3/each so its cheap assurance. I tried out iridiums to go a 10k interval but they aren't any smoother and a little more expensive than 2 changes of coppers so I'll switch back to copper next time.
    May 03 2007
    german
    heaven/hell
    from my experience, iridium plugs suck ass with FI engine.
    Tyler, what copper plugs are you running exactly? I might switch mine as well.
    Oct 03 2005
    Atlanta, GA
    I'm running 3bar FPR. I'll change the plugs at my next oil change (Jan).
    It's relatively cooler down here these past few days, 30's in the early monrings.
    - 3.0 Quattro
    - Hyperflow Intake
    - G3 SuPeRcHaRgEr
    VP of 3.0 CLuB
