Results 1 to 11 of 11
    Nov 12 2007
    '03 A4 1.8TQM
    Washington
    Drvr and Pssngr wheel problems
    Cant locate this problem.
    On my driver side and passenger side wheels, when turning, say more than 30 degrees, as well as turning up a small incline, even backing out, i hear this noise. Have you ever heard the noise a piece of metal makes when its overloaded, cross between a creaking and popping sound? Similar to driving on gravel, or rather turning on gravel/loose rocks. Its more prominent on the driver side but both sides make the noise. Possible wheel bearings? tie rods? control arms? Having trouble finding the problem (never experienced this) Car has 65000 on it, should not be happening but it is. Suggestions? Thank you
    Looking to buy USP Front.
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    Re: Drvr and Pssngr wheel problems
    i saw your post on AF too maybe its you fender liners or whatever its called, do you have bigger wheels? maybe your PS fluid is low? does it do when you drive or only when ur car is parked?
    Nov 12 2007
    '03 A4 1.8TQM
    Washington
    na all that stuff is good checked out. I think it has to do with the assembly, but good call
    Oct 08 2007
    Columbus, OH
    how long ago did it start doing that?
    Nov 12 2007
    '03 A4 1.8TQM
    Washington
    Quote Originally Posted by BOPOH View Post
    few weeks. Fenders are clear, stock 17" sport wheels
    Oct 08 2007
    Columbus, OH
    i dont know what it is, but i think i hear same sounds as you describe. i just dont care too much
    Nov 12 2007
    '03 A4 1.8TQM
    Washington
    if i ever figure it out ill let you know
    Oct 08 2007
    Columbus, OH
    alright, thanks
    Apr 04 2007
    2003 A4 1.8TM, 1987 325, 1987 528
    Columbia/Nashville, TN
    I have been experiencing a popping sound mainly when I'm turning into a parking spot or up a driveway and I hit a bump. Almost all the time when my steering wheel is at full lock or close to it.
    I'm thinking tie rods/control arms. But whenever I take a front wheel off I check everything I can't find anything loose. I just hope my front wheel doesn't decide to fall off one day.
    Robbie
    2003 A4 1.8TM
    Motor F21 Turbo, FMIC, Green Tops, Meth Injection, Motoza Tune, Carbonio, Forge DV, Ecode Test Pipe, Neuspeed Catback, 034 Motorsport Solid Mounts
    Suspension Statis SS, Antera Type 309 18x8
    Interior/Audio Pioneer D/D Head, JL 450/4, JL 500/1, JL ZR650's, 2 - 8 JL 8W7's
    Senior Member Three Rings ThreePointOhh's Avatar
    Dec 24 2007
    |2004 A4 3.0Q 6SPD MT|
    New York, NY
    bushings maybe?
    ** I'm Gonna Drive it Till the Rings Fall OFF!! **
    Aug 26 2005
    Have you checked the CV joints? They can make poping and clicking/grinding noises at large wheel angles if the clearances are excessive or the lubrication is failed (torn boots,)
