Results 1 to 22 of 22
    Jan 25 2006
    A4 2.0T
    MD
    I need your help: Introducing Vag Tuner Tools alpha 0.001
    I have developed a small application that will allow users to upload VAG log files (.csv) directly and have the log converted to an image, and then also host that image.
    This will allow us to post VAG logs in forum posts in a much easier manner.
    I whipped the current version together in a couple hours and it only has basic functionality. I need your help testing it.
    I plan on developing the system into a robust tool for the VW/Audi community.
    VAG Tuner future release agenda:
    WOT auto detect
    The application will automatically detect the area in the log where you are at Wide Open Throttle and extract that region for conversion.
    BT / BAT CAPS calulator
    Coupled with automatic detection of WOT this will allow users to upload the VAG log for automatic calculation and entry into a CAPS like database.
    Automatic ECU type detection
    (Dynamics block labeling based on ECU type)
    Conversion Calculators:
    IDC - Injector Duty Cycle
    mbar to PSI (Boost)
    etc
    etc
    Graphing:
    Try to graph knock voltage to try and identify knock?
    Graph values in log
    End goal:
    A data repository for VAG cars with various modifications. The application will store logs associated with the cars specified hardware.
    The application will serve as a diagnostic tool for users to compare their cars against similarly configured cars.
    For example:
    I want to see what timing looks like for all AEB cars, with a 630cc Tapp tune running a gt3076r @ 23 psi. -- The system would then look for a submitted log that matches that criteria and then display it.
    Please test the application by uploading your vag log at the following address:
    http://vagtuner.dynalias.org
    Then - Copy and paste the URL the application produces into a forum post.
    Thanks for you help.
    Jan 25 2006
    A4 2.0T
    MD
    Re: I need your help: Introducing Vag Tuner Tools alpha 0.001
    First Log!
    this sort of relates to a thought i had today. but my thought was for a little further down the road.
    contact via email please.
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by k0mpresd View Post
    PM your thought or post it in the thread.
    Oct 29 2005
    10speed
    San Francisco, CA
    Sean stop this BS and get me a website son....
    Anyway I got my inch pounds wrench today woot
    - Clint
    Jan 25 2006
    A4 2.0T
    MD
    Go start your car....
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Don Supreme View Post
    go tune your car
    - Clint
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Wish you had that in php. I could let you hop on my dedicated server to host the app. I don't do .Net apps with my server though since it's linux :-(
    P.S. - I just tried to use it and I received the following message, "Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index" when I attempted to upload a csv from VAD Mobile (with and without the first "VAD Mobile" line removed). Shoot me a PM with your email and I can fwd you along the csv file if you are interested.
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by GetBoosted84 View Post
    I code in C#, so no php here, but thanks. I had to do a lot of off the wall configurations to thow this up quickly for people to start using and to help me with testing.
    Apr 10 2007
    Eastern PA
    Gotcha. I use C# and asp.net at work too. Hosting is much cheaper for php so I opted for that language for my personal projects.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Sean.
    Send me an email so I have your address and can send you that *csv file that was 'out of range'
    dougyfresh at vt dot edu
    -Doug
    Jan 25 2006
    A4 2.0T
    MD
    email sent...
    Dec 03 2005
    2 pedals 1FG
    connecticut
    replied, rookie biatch!
    -Doug
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Bump for this, keep it on top!
    Jan 25 2006
    A4 2.0T
    MD
    ^ Thanks ---
    I need more people testing and giving feedback.
    Oct 27 2007
    In the lab
    Jumboblack aka Justin and I did lots of logs and lemmitweaks today, send him a PM to post em up
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by 317ssayzarc View Post
    Nice, did you get his issues sorted out?
    Oct 27 2007
    In the lab
    Which? I added 5ish degrees of timing, 160 rpms to idle, +5% secondary fuel, and 15 to idle torque... Idle is still shadyish, but nuttin like it was...
    Jan 25 2006
    A4 2.0T
    MD
    hmm so does the car pull nicely and have good AFRs, etc?
    Oct 27 2007
    In the lab
    Pulls super smooth, afr's are around 11.9, but they are SPOT on with requested... Timing pull is MAX of 4.5 degrees, misfires are 0, car runs great, ect...
    It felt slow because when I had that turbo (he has it now), I got 2 clean 3rd gear pulls that had boost creep to 20psi by 8k... But thats apples to oranges haha, he can only run the 18psi he is now without making windows in the block
    Jan 25 2006
    A4 2.0T
    MD
    Oh, he upgraded to the 3071 huh..
    nice...
    Look forward to the logs.
    Jan 25 2006
    A4 2.0T
    MD
    I have been observing the server logs and noticed a few vag-com logs that failed to convert. I used those logs to help with testing.
    I have fixed a few bugs and updated the application.
    Please PM me if you guys have problems. I look at the server logs, but a PM would be best if you run into any issues.
    V 0.03
