I was notified about this thread.
Here is how our tuning stands out, since fuel curves and timing are not any secret and all tuners will have this ironed out pretty well.
We SPECIFICALLY make our tunes for manual boost controllers. We want our customers to have control of the boost to adjust for weather and gas.
How?
1. We open the throttle fully at 2k, since K03 cars are at full boost by 3k especially when equipped with a manual boost controller (and not the boost ramp limiting N75). So we don't want to slow this down by leaving it at the 4k setting. This also helps when launching. You tend to not have to rev it up as high to get it to leave really hard due to the throttle being opened earlier.
2. We remove the cars ability to throttle cut and limit boost in the tune (so the owner needs to have a boost guage and be smart)
3. We make the throttle extra responsive to match the characteristics of the manual boost controller.
The cars are still smooth but require less pedal to get what you want. We DO NOT force timing and keep the full use of the knock sensors and its ability to correct.
When you upgrade turbos we only charge a $100 upgrade fee. Our chips are also soldered on and installed in an encryption board so if updates our needed you don't have to send in your ECU and have downtime. video on how the chip is replaced -->
http://jhmtuning.com/videos/JHM_ECU_...ent_How_To.wmv
There is no magic pill to make your car magically faster other than ramming timing down the cars throat and ignoring the knock sensors. We rather use the stock systems ability to protect itself and we work with your hardware on your car (exhaust, intercooling, etc) vs. forcing it to keep the longevity of your engines.
Hope this clears some stuff up, we don't put this stuff on our site so we can consult with each and every customer to make sure our tune is right for them and their goals.
