Results 1 to 4 of 4
    Sep 17 2008
    California
    allroad won't start
    After replacing the turbos the car won't start. the battery was disconnected and engine out. Is there something that needs programmed? It turns over but won't stay on. All the lights work and I'm not getting any codes on the generic ob2 scanner. Any suggestions.
    Established Member Two Rings EnviedA6's Avatar
    May 06 2008
    Minneapolis, MN
    Re: allroad won't start
    Quote Originally Posted by gabec007 View Post
    I would check the MAF or a possible vacuum leak somewhere. When there's a vacuum leak the car will start for a few seconds then die.
    You also may want to check fuel lines as well. Good luck
    Envied A6
    2001 Silver Audi A6 2.7T Tiptronic, APR Stage 2 chip, Blitz custom intake, Dynomax Turbo custom exhaust, Custom down pipes, Turbosmart MBC, Carbon Fiber interior trim, arm rest, engine cover, air box cover, hood,trunk, mirrors, B pillars, eyebrows,Tinted tails & side markers, H&R lowering springs, H&R 5mm and 10mm wheel spacers, 19x9 Konig Next wheels, 245/35/19 Toyo Proxeys 4
    Sep 17 2008
    California
    Ok so there isn't any reprograming issue going on? Some people told me that once the batteries out for a while the car needs to be reprogrammed from the dealer, but the guy I talked to at the dealer never heard about that.
    Veteran Member Four Rings Myallroad's Avatar
    Apr 11 2008
    Independence, KY
    nothing on programming... check the fuel. sounds like a fuel problem.
    10 S4 DSG Sport Diff B&O MMI
    18 Q5 2.0t PP BO VC
