Results 1 to 17 of 17
    a glimpse in to revo switchable files.
    ive only dug in to the file for just a few moments. just a quick glimpse of how revo switchable files work. im assuming the maps are chosen using the sps3.
    well, here you see, in "stock" location, ignition 1 and ignition 2 maps. stock values.
    here are those same maps in revo's version.
    and then way down towards the end of the file, we have these maps where normally there would be FF. i dont know what sort of bits or calls are done to reference these maps. but something somewhere tells the ecu to pull data from these maps instead of the stock location seen above.
    just thought it was interesting.
    contact via email please.
    Feb 27 2005
    North Wales, PA
    Re: a glimpse in to revo switchable files.
    what the fuck did you just say?
    hahaha
    im assuming that the ignition tables waaay at the end of the file where normally there is nothing but FF's are the maps that the ecu pulls data from when changing timing using the sps3. instead of the stock location.
    Feb 27 2005
    North Wales, PA
    you just blew my mind.
    :p i need to do more digging. and i need a lot more knowledge on programming. read: any knowledge would help.
    Feb 27 2005
    North Wales, PA
    i've only had basic c++ so i am no help.
    you should be working to get boobies on my instrument cluster
    that box is really interesting the way it works. it seems to intercept the canbus communication going from the radio > cluster. and then inserts a new message for the cluster to display. sort of a simple concept. im sure it takes some knowledge to figure out though. im sure you would need can communication knowledge and knowledge on the firmware in the cluster (so you know how it displays the messages it receives.)
    Veteran Member Four Rings Rosati's Avatar
    Nov 17 2004
    B5 Brilliant Black A4 1.8TQM
    Northern New Jersey
    Nice work
    I lack those "AZN" skills
    * Gone but not forgotten - BTA4 GT28RS w/ all mods 400chp
    https://www.facebook.com/media/set/?...1463643&type=3
    Current: 1994 Mazda RX7 Chaste White
    DIY B5 Head Replacement Guide: http://www.audizine.com/forum/showth...al-and-Install
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    AZN= AudiZine Nerd? Haha jk. How did you access the maps?
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Sep 19 2006
    Boston
    if you can pull what location where the cruise control hooks code from you can make a cruise control switcher easy(i have the ecu schematics if interested). But i beleive that the code down there is just a process for a multiplier, im pretty sure if you look at the map it will show it being multiplied by so much in a certain range... and the program has a call to for that range somewhere
    B5 Imola S4
    B9 Black SQ5
    B7 Silvaro S4
    i still dont know exactly how the ignition equation is calculated. there are 4 ignition maps. 2 optimal ignition and 2 ignition. all me7 files seem to have those.
    i dont think the bottom ones are multipliers as they are 12x16 and have the exact same starting data. just data at the end is raised. and look at revo's timing at bottom right in the stock location modified map. it is slammed compared to stock.
    about the cruise control part, pm me please. :)
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    you might want to call that in dev0's version to keep urself out of trouble
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    whatever just happened went way over my head
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Sep 19 2006
    Boston
    you still on aim? probably easy to talk that way, i also have some files that might be of some worth to you... your'e mycarbl*** on aim right?
    B5 Imola S4
    B9 Black SQ5
    B7 Silvaro S4
    thats me.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    That reminds me of HP-Tuners, when we were tuning the notorious Vette I bring up occasionally.
    Basically, those values are tweaks to timing intervals(BTDC to ATDC degrees) and/or duration.
    some quotes.
    1. A method for providing a user a range of performance levels based on first and second performance lookup tables written into an engine control unit (ECU), comprising: a) providing first and second performance lookup tables in the ECU; b) assigning first and second constants corresponding to the first and second performance lookup tables, respectively; c) providing a range of variables disposed numerically between the first and second constants for selection by the user; and d) generating a third performance lookup table corresponding to the variable chosen by the user by linear interpolation between the first and second performance lookup tables.
    5. A method as in claim 4, wherein said linear interpolation comprises: a) multiplying the stock 3-dimensional lookup table by (1-variable); b) multiplying the chipped 3-dimensional lookup table by the variable; and c) adding the results of a) and b), where the variable is 0.0 for the stock 3-dimensional lookup table to 1.0 for the chipped 3-dimensional lookup table.
    12. A method for reprogramming an engine control unit (ECU) having a stock performance lookup table, comprising: a) establishing communication with a communications port of said ECU; b) reprogramming the ECU with a chipped performance lookup table through the communication port; and c) said reprogramming includes allowing a user to choose at least the stock performance lookup table or the chipped performance lookup table or another performance lookup table generated by linear interpolation between said stock and chipped performance lookup tables, such that the user can select to operate the ECU at least at the stock performance lookup table or the chipped performance lookup table, or in between the stock and chipped performance lookup tables.
