Results 1 to 38 of 38
Thread: APR problems
    Sep 14 2006
    Australia
    APR problems
    this is what happens when your local APR dealer says your cam lobe is ok and then gives me the cam lobe at a later stage and not installs it!
    make sure you insist they install this vital bit of hardware as it may save you $5000
    Audi A4 B7 Sline 2TQ
    APR programs,APR K04, APR exhaust, APR fuel pump, Carbonio CAI, KW V3's, RS4 Grill,RS4 rear swaybar, 20'' Verde kaos,Defi boost gauge, Racetec FMIC
    Established Member Two Rings Mtepete's Avatar
    Jun 17 2008
    2005.5 A4 Black 20% Tint
    Hartford, CT
    Re: APR problems
    im sorry totally not an engine guy... what is a cam lobe?? and is this something that happenined cause youre car was chipped?
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: APR problems
    more APR issues, then need to get on here and resolve these
    Nov 05 2007
    Auburn, AL
    Re: APR problems
    Quote Originally Posted by nsmith12 View Post
    This is not our issue but an issue that even stock fuel pumps experience as a result of an issue Audi/VW was having with the factory intake camshafts. The camshaft failure caused the pump to look like this. If you read the instructions we provide with each pump, you will see a factory TSB concerning issues with cam lobe wear on stock vehicles. These instructions are in the box with every pump.
    http://www.goapr.com/Audi/support/fs...stallation.pdf
    To B7!:
    I am sorry that you are going through this but this has been a known issue on the 2.0T FSI engines for some time. That is why Audi/VW have issued the TSB and also why we include a copy of our installation manual including the Audi TSB in every pump box. In addition, as you can tell, the installation manual is also on the web. For a technical explanation of what happened to your cam lobe, please read the Audi TSB at the end of the document the comes from the link I have provided. If you have any other questions, please call us at 1-800-680-7921.
    Nov 12 2007
    Grand Junction, CO
    Re: APR problems
    Mike: The problem isn't him. It's your dealer that said it was okay and clearly had no idea what he was talking about. I think that your dealer should pay for the damage, if what B7 said was in fact true. You see the problem here?
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Re: APR problems
    So you are saying that I should go to the dealer and have them inspect the cam lobe regardless of whether I have a chip? (which I don't)
    Nov 05 2007
    Auburn, AL
    Re: APR problems
    Quote Originally Posted by AudiWxGuy View Post
    I understand your point. However, I need more detail about how long this system went unchecked between the dealer giving the okay (if that's what happened) and the failure actually occuring. No matter what pump is on the car, stock or modified, this cam lobe setup needs periodic inspection. That's why it would be good if B7! would call us.
    If you read our installation instructions, we clearly warn the customer about this situation and what must be done during installation and thereafter to ensure longevity. We didn't do this because our pump is special. We did this because the camlobe wear issue was well known and documented. The TSB was out before we even released the pump.
    Nov 05 2007
    Auburn, AL
    Re: APR problems
    Yes. That is what I would recommend. Chip or no chip, stock or aftermarket pump...it doesn't matter. This issue has been happening on stock cars since the release of the 2.0T FSI. However, since Audi chose to issue a TSB instead of a recall, they are not going to touch your car unless you complain of fuel cuts and can prove it with specific Diagnostic Trouble Codes (DTC's) stored on the ECU.
    Sep 14 2006
    Australia
    Re: APR problems
    Quote Originally Posted by Mike@APR View Post
    i did about 5000k's on the pump... yes great your instruction all say this and its up on your sight but i take my car to an APR dealer for a reason and that is for them to look after me you would expect that when you have spent $15,000 on them.
    but anyway thats not what my thread is about... i posted this up as a warning to everyone to have things like this looked at and most importantly make sure the APR dealer does there job properly.
    Nov 05 2007
    Auburn, AL
    Re: APR problems
    Quote Originally Posted by B7! View Post
    5000 kilometers on this setup is nothing provided that the car was good to begin with. Think about what I would be going through if you could only run this pump for 5000 kilometers (3106 miles) without this happening. Every Stage 3, S3-K04, and Stage 2+ w/ Pump customer is running this assembly and that provides all the reason I needed to warn people upfront about the Audi factory issue.
    As I said, I am very sorry that this happened to you. I have communicated your situation to Keith, who is our director of sales and tech support, and he will work with you to get the issue resolved. Please contact him at your earliest convenience at 1-800-680-7921. Don't worry, we will do our best to get this situation resolved for you.
    Sep 14 2006
    Australia
    Re: APR problems
    when they looked at it they said that the lobe was fine.. i insisted that they look at it and if it needed changing they would but then when i picked up the car they said it had a few scratches on it but it looked good otherwise, at the time they never had any lobes in stock and gave one to me at a later stage but they never installed it.
    Nov 05 2007
    Auburn, AL
    Re: APR problems
    Thanks for providing the history. Not to worry, we will help you out on this. Give Keith a call with the number I provided and he will help get you sorted out. I have already talked to him about this and he is expecting your call.
    Nov 12 2007
    Grand Junction, CO
    Re: APR problems
    Excellent! Glad to hear you guys are providing great customer service!!
    Sep 14 2006
    Australia
    Re: APR problems
    mike that number is incorrect
    maybe its because i am in Australia... i have sent an email to Guy in australia but he hasnt responded
    Nov 05 2007
    Auburn, AL
    Re: APR problems
    Keith is not in the office right now because it is 9:51pm CST in Alabama. Guy had a pretty serious medical issue so he was unavailable.
    Please call us at 334-502-5181. I think you will have to dial it with some numbers in front to call internationally but this number should work. I think you would dial 001-334-502-5181 from Australia.
    Jan 06 2008
    Dacia Sandero
    Arizona
    Re: APR problems
    Good work APR.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stërn . 034 . OEM+
    Oct 19 2008
    fl
    Re: APR problems
    The correct number calling from Australia should actually be 0011-1-334-502-5181 and if he doesn't have an international long distance plan, he'll pay big bucks for that call.
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Re: APR problems
    glad to see apr is working on the issue!
    The usual things!!
    Resistor Install
    Sep 14 2006
    Australia
    Re: APR problems
    Quote Originally Posted by Alky View Post
    its all good buddy i have a good international plan at my office!
    Feb 16 2008
    Oakdale, MN
    Re: APR problems
    you're going to fly to APR??
    The usual things!!
    Resistor Install
    Sep 14 2006
    Australia
    Re: APR problems
    Quote Originally Posted by cstarky15 View Post
    thats the plane!
    Feb 16 2008
    Oakdale, MN
    Re: APR problems
    thats the plane!
    sorry I had to.
    The usual things!!
    Resistor Install
    Veteran Member Three Rings Nico's Avatar
    Mar 02 2007
    Sydney, Australia
    Re: APR problems
    Simon, make sure you do contact APR about this especially with the run you have had. They will be able to help you get your car sorted. Hopefully save you some cash.
    Good luck.
    Nico
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Re: APR problems
    Offcourse...Chipped or no-chipped it doesnt matter...
    Stage 2 Banner Advertiser Four Rings
    Jul 11 2005
    04 Audi S4, 04 VW R32, etc....
    Auburn
    Re: APR problems
    No need to call us if you would like to avoid any charges, we can get this resolved via AZ!
    If you would like, please send me a pm or email at [email protected]
    Sep 14 2006
    Australia
    Re: APR problems
    Quote Originally Posted by Keith@APR View Post
    email sent!
    Sep 14 2006
    Australia
    Re: APR problems
    have sent you 2 emails now with no response!
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Re: APR problems
    lolz
    by the way, i commend you mike, for your excellent customer service.
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    Re: APR problems
    welcome to APR
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Re: APR problems
    Should have really contacted APR directly to give them a chance to address the issue before creating a negative post on a public forum...
    Glad to see APR is providing first class customer service though.
    Sep 14 2006
    Australia
    Re: APR problems
    Quote Originally Posted by elwigglero View Post
    already did buddy!!
    i contacted the australian distributor and they never got back to me and then i contacted my local APR guy and he just said, "good luck fixing this problem its going to cost you a lot of money"
    Sep 04 2008
    Lansdale, PA
    Thumbs up Re: APR problems
    already did buddy!!
    Then I'd have done the same thing. Good luck with the problem.
    May 13 2007
    Brisbane
    Re: APR problems
    already did buddy!!
    Hi Simon, I answered your email this morning, - sorry, I spent the most of the past two weeks in Hospital.
    Keith at APR has all the details & waiting for him to get back to me (put a call into him today).
    Veteran Member Three Rings Jay B7's Avatar
    May 08 2008
    2005 S4 Avant Quattro; 2014 Honda Pilot Touring 4WD 2007; GSXR 600; 2019 VW E-Golf
    SF Bay Area
    Re: APR problems
    They are going to have to provide first class service now since everyone on AZ is reading this...
    Tap, Snap, or Nap!!!
    2005 B6 S4 Avant; 2007 B7 A4 2.0T Quattro; 2007 GSXR 600;
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    Re: APR problems
    LMFAO apr pumps....
    this will keep happening if you keep leaving your car unchecked
    i check mine every oil change, and replace if need be. but then again... REVO runs no where near as rich as APR, so therefore less stress on the fuel pump.
    i reccomend everyone running aftermarket fuel pumps to check their cam follower cap AT LEAST every other oil change. (i cant risk anything, and i run really agressive settings, so i check mine every oil change)
    and for the record i have had several cars at my friends shop go down because of this, im only looking out those who it hasnt happened to yet...
    good luck everyone
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Veteran Member Four Rings AWDTURBO's Avatar
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    Re: APR problems
    Quote Originally Posted by Ih8OEM View Post
    LMFAO apr pumps....
    good luck everyone
    Does that mean running REVO would be safer for our stock fuel pumps?
    Veteran Member Three Rings mrponline's Avatar
    Sep 18 2006
    2008 Audi S5, 2007 VW Golf R32
    Sydney Australia
    Re: APR problems
    Simon sorry to hear that your having problems with your car again... You and Nico have had a pretty bad run with your APR mods.
    In a way im glad i sold my B7 when i did, i never had any major issues but i never got around to upgrading the turbo. I guess i have to thank APR for that as after 8 months of empty promises, being stuffed around and my car being disabled i sent the KO4 kit back.
    Lets hope APR does the right thing by you and sorts this out.
    2008 Audi S5 6MT
    Phantom Black, 20" Forged DPE 3 Piece Wheels, Nitto Invo 285/25 Tyres, H&R Suspension
    2007 VW Golf R32 6MT
    2006 A4 2.0T Quattro 6MT Sline - SOLD
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Re: APR problems
    Quote Originally Posted by AWDTURBO View Post
    Yes and no...
    That looks like what happened to me, but on mine it was just the cam and the fuel pump, not the engine.
    If you have a fuel pump, CHECK THE FOLLOWER every oil change ( Specially with the old cam ).
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
