Results 1 to 11 of 11
    Senior Member Two Rings dennisS4's Avatar
    Mar 23 2008
    Tri State aRea
    Rough start up!?!?
    So yesterday i get out of class at 5:20pm and get in my car to take off and it cranked for like 4 seconds so i stopped cranking. I took the key out and let it rest and check that everything visible was ok under the hood(i.e intake, DV's,) and it was.
    I got back in and cranked it for about 3 seconds and gave it some gas and it turned over with a good rev up to about 3000 RPMs.
    Has anyone else been experiencing this? I'm assuming its the change in weather.
    Thanks for any input,
    -Dennis
    Senior Member Two Rings sti4now's Avatar
    Oct 21 2008
    Turbo M3
    NC
    Re: Rough start up!?!?
    I have heard this happens when the weather starts getting cold with these cars. How are your plugs?
    Mar 23 2008
    Tri State aRea
    haven't checked, i will change them out when i do the timing belt withing the next few weeks.
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 10 2007
    whats your volt gauge say? Battery.. a possibility
    2000 s4
    Fairfield, CT
    if it slowly becomes a no start prob a coolant temp sensor. i bet there is a DTC code for that pending in your computers memory even though the light might not be on. take a look easy fix if it is
    i heart my s4
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    Thats never happened to me (knock on wood), even with the cold weather im the morning... you battery could be dying... or it may be the coolant temp sensor as mentioned above... vag it..
    Mar 23 2008
    Tri State aRea
    Quote Originally Posted by rms-s4 View Post
    Is there a diy on this? i think this is what it is going on for sure.
    Aug 10 2007
    Check the battery too..
    Mar 23 2008
    Tri State aRea
    battery is good, this only happened that one time as of now. but my check engine light is still on... im almost positive its the coolant temp sensor.
    2000 s4
    Fairfield, CT
    its on the right side of the motor behind the combi valve on the back of the head
    i heart my s4
    Senior Member Three Rings Muck_and_Grind's Avatar
    Jun 09 2008
    2001.5 Audi S4 (on stands), 1989 Grand Wagoneer, 2007 B9 Tribeca
    Lodi
    mine is/ hopefully soon, was a warped head. it would turn over then stop.
