Results 1 to 16 of 16
    Senior Member Two Rings keithla4's Avatar
    Oct 31 2007
    02 audi a4 quattro man
    oregon
    third thermostat in 2 years any help would be great
    like the tittle says i have replaced my t stat two times and now going on the third one it keeps sticking open has this happened to anyone else in here im getting tierd of changing it and i have replaced the ECT everytime i change the t stat and i just changed it agian this morning and it didnt fix it the stat is stuck open im getting really pissed off and every stat is from audi direct help me figgure this out
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    Re: third thermostat in 2 years any help would be great
    Only on my second one but it was messy when I had to replace it. The seal broke on the thermostat causing a MAJOR coolant leak. So make sure you keep replacing them if they are getting stuck open.
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    Sounds abnormal. Are you using g12 coolant? Not mixing or topping off with other types? Mixing = bad.
    buying OEM t-stat or aftermarket? I assume there is an aftermarket. Try another brand.
    This is all I can think of.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Oct 31 2007
    oregon
    yea i am using g12 coolant and the t stat and ect are both oe from audi parts
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Have you inspected the wire going to the thermostat? That is for the heating element within the thermostat. The thermostat is MAP controlled based upon inputs from the other coolant sensors. As those sensors provide data to the ECU the ECU then sends a voltage to the heating element to adjust the thermostatically controlled springs (heat changible springs) within the thermostat to regulate coolant flow.
    What I am getting at is, perhaps, the wire has a short causing the thermostat to always be open. If that is the case, your thermostats are OK but your wiring harness needs attention.
    1) check continuity on that wire from somewhere upstream to the connector on the thermostat
    2) check resistance on that wire. What is an acceptable value? I do not know.
    -Doug
    Dec 25 2004
    Earth
    1.8T or 3.0L engine?
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    I'm going through the same thing right now. It used to warm up slightly between cold and middle but now the fans turn on after startup and I never am above cold. The audi connection said I need a new tstat
    Registered Member Three Rings kovalevandrew's Avatar
    Oct 19 2008
    South Africa
    Trust me, i know ALL about those bastard thermostats. Been through 5 of them in the two years... Ever since i change to a new dealership after moving house.
    The new one was screwing me with the replacing of coolant. One bottle of the G12, and not the G12 Plus, and the rest water.
    So after getting a lecture(for over 2 hours) from a guy who was at a friends place when i was there for a party. He does all the servicing on the S/RS models only at one of the bigger dealerships here.
    To cut a very long and drunken story short... G12 Plus, and ONLY G12 Plus goes into your car as coolant, not a drop of anything else, heaven forbid water.
    Since doing that, no thermostats getting stuck open, no overheating, no coolant spraying out all over the place after driving the car hard, and i drill my car.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I run about 90% water and 10% G12
    no problems here.
    sometimes I run up to 99% water.
    -Doug
    Oct 19 2008
    South Africa
    When engine code you running...?
    APU is mine. I know they fixed a lot from the motors in the B5 to the B6.
    I run mine hard to well over 7500rpm everyday. If i put any water in, cooling system as a hissy fit.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    It was AMB (1.8T for the B6 in North America)
    Now I have a built 2.0L stroker using an AMU block but with my AMB thermostat and external accessories.
    -Doug
    Oct 19 2008
    South Africa
    Wow, nice. What figures you getting from it...?
    Mine is a 2001.5 B5. Was literally the last B5 1.8T sold in SA. No stock 2.0T comes even close, they simply too slow. The new S3's have me on launch, half way through third i go flying past them. Not bad for a car with over 210 000km on it...
    I know a lot of people here have problems with their coolant systems. Running only G12 is the only thing that works.
    Oct 31 2007
    oregon
    so what your saying is not water just g12 plus i have never heard of that ever and i read up on the t stats on our cars by the way it is a 1.8t AMB and know i know why the damn things are so much money well im going to change it agian and try running straight g12 plus i hope it works this time any ways i wanted to pull my intake manifold and powdercoat it
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by kovalevandrew View Post
    It is still getting tuned. I'll have numbers once its tuned.
    -Doug
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    hmm i work at a dealer and its a 50/50 mix of g2 and water on every car even the rs4 and rs6's
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Oct 29 2005
    10speed
    San Francisco, CA
    Ya where are they at?
    - Clint
