Results 1 to 14 of 14
Thread: KO3 for a KO3s
    Veteran Member Four Rings kampfer's Avatar
    May 18 2008
    Also on the Curb:: VW Passat
    SOOOOOO Cal
    KO3 for a KO3s
    Ok so I am starting to hear a high drill noise coming from my turbo so before i blow it up i went and got a KO3s from a friend of mine is it difficult to swap these out and replace it or is it just a plug and play, will i have to tune it or flash the cpu? I also have to install a new cat is there a DIY on how to install a new KO3s or something to help me out? Should i get someone to do this for me or is it soooo easy that i should just do it myself?
    Thanks
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    Re: KO3 for a KO3s
    Direct bolt on
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    May 18 2008
    SOOOOOO Cal
    Re: KO3 for a KO3s
    yeah cool so i shouldnt have to get flashed or anything how long will it take and is there any special tools i need?
    Sorry this is my first Audi not to mention my first turbo car.
    Thanks. oh and if there is a DIY could you send me link?
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    Re: KO3 for a KO3s
    just take old one out throw new one in... Thats it...
    Aug 16 2007
    Buffalo NY
    Re: KO3 for a KO3s
    just take off all the turbo tubes and remove the intake then unbolt the down pipe from the turbo then unbolt the turbo... then reverse reverse... cha cha now ya'll
    May 18 2008
    SOOOOOO Cal
    Re: KO3 for a KO3s
    heh, ok well looks i could do this tonight right? any problems im blaming you guys for assuming that i could do this.
    Aug 16 2007
    Buffalo NY
    Re: KO3 for a KO3s
    you will have an issue with the one bolt on the down pipe...its a bitchface to get to
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    Re: KO3 for a KO3s
    it will be super easy, just take the airbox out and disconnect everything, swap and you're done. the worst part will probably be the mess from the oil and coolant lines.
    {99.5 Avant}
    Oct 27 2006
    Pearl 98.5 Audi A4 1.8T
    Fargo, ND
    Re: KO3 for a KO3s
    Don't forget to prime it - Check out audi DIY for a K04 upgrade - same instructions
    Here is the link
    http://www.audiworld.com/tech/eng27b.shtml
    1998.5 1.8TQT (SOLD)
    Joined the Dark Side
    2008 Honda Pilot SE
    May 18 2008
    SOOOOOO Cal
    Re: KO3 for a KO3s
    ah, so not so easy after all ok looks like i wont be doing it tonight i need it for mannana i have class at 730. DIY helps thanks akielb.
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Re: KO3 for a KO3s
    It probably will take you 5-7 hours to do it, including the cat. It took me 9 hours my first time including changing the manifold, but not the cat since I already had a test pipe. Also don't forget to buy all new crush washers and gaskets, oil and coolant, and a new oil filter since you might as well change your oil at the same time.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    May 18 2008
    SOOOOOO Cal
    Re: KO3 for a KO3s
    OH DARN! do you have part numbers for the gaskets? I don't want to seem like a complete idiot but I normally do everything myself on my car but with something like a turbo i want it done right not all cheapo like i do it may be i should take it someplace how much do you think that would cost me?
    Sep 23 2007
    Re: KO3 for a KO3s
    washers are like .40 and the gaskets shouldnt be more then $10
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: KO3 for a KO3s
    Quote Originally Posted by Killerteve View Post
    It probably will take you 5-7 hours to do it...
    Huh? I did it with my dad's shitty tools in <3.5hrs and on my back. Including running to the store to get a 6mm allen socket.
    If you have all the correct tools up front, you should be able to do it in <3hrs, provided you have some mechanical knowledge and your exhaust has ever been off since the factory put it on.
    Quote Originally Posted by kampfer View Post
    ECS tuning has a "K0x turbo install kit" with all the gaskets you'll need.
