Results 1 to 4 of 4
    Veteran Member Four Rings Betty Humpter's Avatar
    Oct 04 2006
    1993 Ur S4(cinny),03 A8L,11Yamaha Griz 4x4; 12 Yamaha 450
    Pittsburgh
    My hood wont open! HELP!!
    It is a 2005 A8 L the drivers side will release, but the passenger side wont release. It doesnt even make a noise when i pull the lever. Does anyone know how to get in there and release the catch?
    Please help!!
    KURTTRO
    "If speed kills, then do brakes give life?"
    1993 Ur S4 "cinny"
    2003 A8L
    2011 Yamaha Grizzly Special Edition
    2012 Yamaha Grizzly 450
    Active Member Two Rings mataylor1's Avatar
    Aug 21 2008
    2008 A4 SE 2.0T Quattro
    Falls Church, VA
    Re: My hood wont open! HELP!!
    i know this sounds funny, but take the side of your hand and give it a little bump, dont pull, maybe even have someone hold the lever back to pop hood and make a fist and give the side of the hood that won't open a good but not too hard jolt, should pop loose, unless more serious problem, but that u8sually works. i used to work for audi and saw that a few times. good luck
    Sep 15 2008
    Upstate, NY
    On my URS6 I had to get a broom handle and fish it up from the bottom to manually push the latch. If you get a flashlight and jack up the car you should be able to see where the latch is. Might work for an A8?
    Oct 04 2006
    Pittsburgh
    i will try!! Thanks!!
    KURTTRO
    1993 Ur S4 "cinny"
    2003 A8L
