Results 1 to 27 of 27
    Senior Member Two Rings DOBERMAN@UA's Avatar
    Sep 15 2008
    A6 c6 3.0 Tdi (300hp)
    Ukraine, Kiev
    Spacers to feet OZ ultraleggera 18x8 ET45 with 245/40/18 tires
    Finally installed OZ, it rides much better than my old ABT rims. But it needs to install spacers for better look. What maximum size of spacers it is possible to install for rear and front sides with 245/40/18 tires?
    A6c6 3.0 tdi(300hp), koni sport shocks, eibach pro kit springs, q5 4pot brake calliper, a8d3 sport seats
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Re: Spacers to feet OZ ultraleggera 18x8 ET45 with 245/40/18 tires
    mmmm...finally...I'd love to see how the 245 sits in the 8 width wheel...
    Cause that's what i will do in the next tire change propably...
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    10mm all around would be flush with the fender i believe
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    I'd check to make sure that you're 100% positive that your ET is 45 first because my ultraleggeras are an ET35. Below is a pic with no spacers and 245/35/19's and ET35. So if you put a 10mm spacer on, you would be the same width just an inch smaller on diameter. I personally like this setup and wouldn't go any wider because I have already rubbed off a good deal of paint on my wheel well. However if you wanted to push it, I wouldn't go more than a 15mm spacer in the back and maybe an 18mm-20mm in the front. Remember it also depends on your stance and how much camber you want to have.
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Sep 15 2008
    Ukraine, Kiev
    Quote Originally Posted by Doctor View Post
    )) IT rides much,much better then my 16 kilos ABT rims))))))))))))))))), right now I have 235\40, winter is comming soon in Ukraine, so in spring I'll buy 245..
    Sep 15 2008
    Ukraine, Kiev
    Quote Originally Posted by Glassnpowder98 View Post
    so with 245/40/18 and 15mm spacers I would have no issues? Have you got picures of rear side of the car?
    Mar 07 2008
    Audi A4 B7
    VA
    Not at the moment... But I'll try to take some pictures tonight and post them.
    Sep 15 2008
    Ukraine, Kiev
    thanks!
    Jun 02 2008
    Greece
    Waiting for pics as well even with 235s on them...
    OFCOURSE the difference is significant...OZ Ultras are supreme wheels...
    Mar 07 2008
    Audi A4 B7
    VA
    Here are the pics I promised... Again, they're 245/35/19's on a 19x8 ET 35. After looking at the pics it looks like I have more room in the rear than I do in the front. I always thought it was the other way around. Also, if you look closely at the pics, you can see a little bit where it has rubbed the paint off. The right side is a little worse from when I went to the track; there was a banked left turn that was making me rub a whole lot.
    Sep 15 2008
    Ukraine, Kiev
    [QUOTE=Glassnpowder98;3009191]Here are the pics I promised... Again, they're 245/35/19's on a 19x8 ET 35. After looking at the pics it looks like I have more room in the rear than I do in the front. I always thought it was the other way around. Also, if you look closely at the pics, you can see a little bit where it has rubbed the paint off. The right side is a little worse from when I went to the track; there was a banked left turn that was making me rub a whole lot.
    QUOTE]
    Thanks a lot for pictures! Your car looks great!
    So I can put only 10 mm spacers for 45 offset not to have a problems...
    Sep 15 2008
    Ukraine, Kiev
    HI, here is one morning picture
    http://www.audizine.com/forum/album....pictureid=1448
    Jun 02 2008
    Greece
    Are you sure they are 45 offset..? As I see them I think they could be 50 offset...
    They sit more on the inside of the car than mine which are 45...
    Dont know though...
    The 235 sits fine on the 8width and propably so does the 245...No worries then
    Sep 15 2008
    Ukraine, Kiev
    Dont know though...
    I need spacer, for now I'm not shure with wich to go 10 vs 15 mm... It is 45 offset, and rear axle looks like a crap without spacers....
    Jun 02 2008
    Greece
    ^^^ Yeah but mine is 45 as well and doesnt nearly look as bad as yours on the pic...Thats y it seems a bit weird and I asked you...
    Sep 15 2008
    Ukraine, Kiev
    I'll check on week ends when I'd be chenging them for winter tires///
    Mar 07 2008
    Audi A4 B7
    VA
    Wow, that offset is pretty crazy on your car. I can definitely see why you want a spacer. It will make it look so much better! Do you have plans to lower the car? If so, I'd suggest getting spacers that make your offset ET32-35. So either a 10mm or 15mm depending on what your offset is probably what I'd do.
    Sep 15 2008
    Ukraine, Kiev
    Now you understand why I'm upset with it....My warranry ends in spring, then I'm considering of PSS9 suspension...and have dilema if Ihave ET 30 with 245 tires would It have any issues?
    Mar 07 2008
    Audi A4 B7
    VA
    That could be close but it would probably work... How low are you planning on dropping it? If you start getting some rubbing, you can always give it some negative camber to tuck the wheels in a little bit. When I first got my wheels and coilovers I tried to go for the slammed look and barely had a finger gap between the tires and fenders all around. I ended up raising the car because I couldn't deal with the constant rubbing. I got it raised about 3/4" and now it only rubs at higher speeds when I hit pretty big dips in the road.
    Sep 15 2008
    Ukraine, Kiev
    I don't now for how much I'going to lower it...We have terrible roads here in Ukraine, but as low as possible for safe driving on a road.... What do you mean by 3/4? Is that 25 % lowered compared with standart sport suspension?
    Mar 07 2008
    Audi A4 B7
    VA
    Sorry I should have realized you probably use the metric system. I raised the car 3/4 of an inch (about 19 millimeters) from what I originally had it at because it was rubbing going over almost every bump.
    Jun 02 2008
    Greece
    Hahaha...Yeah...we the metric ones suffer in here...
    Sep 15 2008
    Ukraine, Kiev
    ))0 Raised from what position? From standart or sport suspension position?
    Sep 15 2008
    Ukraine, Kiev
    Anybody use ET 30 rims? With what tires? Any problems?
    Mar 07 2008
    Audi A4 B7
    VA
    Quote Originally Posted by DOBERMAN@UA View Post
    Raised from the slammed position I originally had my coilovers set to. Unfortunately I never measured the height from the fender to the ground when it was slammed... But now I believe it is either 25 1/4 inches (641 millimeters) or 25 3/4 inches (654 millimeters) I can't remember.
    Sep 15 2008
    Ukraine, Kiev
    Dont know though...
    I double check offset is ET 45
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    the red car in the back is AWESOME!
