Results 1 to 12 of 12
    Established Member Two Rings lask8ter134's Avatar
    Sep 07 2007
    Audi A4 B7
    Whittier,CA
    stock diverter valve finally went out!!
    I noticed that Audi now makes a newer version of their stock C valve, calling it the G valve. Has anyone replaced their diverter valve with this new and improved one? or do you recommend going with a forge or evo ms diverter?
    Audi A4 Non-Sline 2.0T Fwd Cvt Evo Ms Intake/Apr 91/100/Miltek 200 Cell Cat/Magnaflow Exhaust/Vogtland 35mm springs, Koni Sport Shocks/R8's Replicas w Toyo Proxy 4's/Hawk Ceramic Pads/Front Filler Plate/30% tint/Garmin 760 GPS
    Oct 07 2008
    Michigan
    Re: stock diverter valve finally went out!!
    I had my stock DV and the red rubber membrane in it tore at about 10K miles. (ive had my car chipped since around 2K) I purchased the forge valve and love it. Its a really high quality part and it sounds pretty sweet, and also you wont need to worry about rubber parts ripping or tearing in the future. I think its worth every penny.... Good luck!
    Veteran Member Four Rings whitevdub's Avatar
    May 10 2007
    Long island
    when your diverter valve tore was it a constant woosh sound? or can you control the sound when you double push on the gas pedal
    Sep 07 2007
    Audi A4 B7
    Whittier,CA
    i can more less control the sound, when I step on the gas at around 3k rpm is it noticeable. Its obviously torn because I notice a power loss.
    May 10 2007
    Long island
    i have that too...but i have n performance mods except for a bmc air filter so whats up with that. i dont even notice a power loss which is weird
    DUH! an Audi
    los angeles, CA
    G is the latest one, supposedly it is the best one at the moment...my friend tore his, but he is just insane for boost! haha
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    go with the latest DV, if you are under warranty... out of warranty go with AWE... save money over Forge... IMO
    Veteran Member Four Rings Bllzll's Avatar
    Jun 09 2008
    b8
    how much is the AWE compared to the forge???
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    ^^130 vs 250
    The usual things!!
    Resistor Install
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Both our G valves, and the AWE valves are great options on the 2.0T. The AWE reacts quicker than the slow piston of the Forge, and of course it's cheaper!
    Stock "G" Valve
    AWE 2.0T DV
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    The Forge valve has a documented delay between vacuum and actually actuating. However, all vacuum-operated valves are going to have this delay. Can't beat the stock electronic valves for fast actuation!
    whitevdub, the noise from double-pressing the gas pedal is compression surge; when you press on the gas again, it closes the valve thinking you're going to stay on the gas and leave the throttle open. However, if you don't, it still doesn't re-open and instead the pressure goes back to the turbo. I recommend not doing that anymore, lol.
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Veteran Member Four Rings fusionx's Avatar
    May 17 2008
    07 A3 2.0T
    Socal / Boston
    the new audi stock DV is the way to go, no reason to spend 300$ on the forge
    07 A3 2.0T S-line - REVO stage 2 - GIAC DSG Flash - AWE downpipe - Custom staggered quad-tip exhaust - H & R springs - H & R sway bar - Neuspeed CAI - fog housing LEDs - VMR boost gauge - JL 12'' Sub w/ Precision Power Amp
    Instagram: @superseany
    CanyonRacerMotorsports
    Project Matte Black: COMPLETE
