I took a look around the search and gathered up a few things but I think my problem relates more to the sifter. Seems that when I shift from first UP into second and NOT down into second its really rough. It is worse on a cold start and gets better as the car is driving. Could it be the syncros or something else. I was going to change the fluid and get the jhm shifter to see if that helps because maby im overthrowing the stick because its not aligned correctly. Idk what to do all I do know is that when I took off the shifter plate there was a divit in the the plastic going into second so maby that could be the cause. any help. thanks.
