Results 1 to 23 of 23
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Wohoo! 4 rotors arrived today w/pads!
    Sweet! $259.88 to my door. $77.96 cash back from Microsoft Live Search.
    Front rotors are 22.4lbs each. I guess I haven't picked up a rotor in a while.
    I'll install them in a few and have pics up.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Sep 27 2007
    Columbia, SC
    Re: Wohoo! 4 rotors arrived today w/pads!
    Ok so looking at the tips on how to remove the front caliper, which is easier?
    Remove TORX?
    Remove 18mm bolt?
    96 Soarer GT - Gone
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    remove the two Remove 18mm bolts with an impact gun, it make short work of getting them out or get a breaker bar and spray the bolts with P blaster, ( also spay them with P blaster if useing impact gun) When you re install them put a little never seize on the bolts and TQ them to 90 foot pounds or Tq I belive, this is how i did mine when i did my brake work in the summer. Good luck
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Sep 27 2007
    Columbia, SC
    Quote Originally Posted by S4_NE View Post
    I'll prolly swing by Home Depot for the 18in wrench (just found out I don't have one) along with some PB and a engine leveler.
    96 Soarer GT - Gone
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 10 2007
    How do you get a Microsoft Live Search discount??
    Thats a great deal!!!
    Sep 27 2007
    Columbia, SC
    Quote Originally Posted by Dowskeet View Post
    1. you have to sign up for a microsoft live account (hotmail counts).
    2. You use the live search to look for an item.
    3. If an ebay link shows up use it and it will go into ebay with the 30% discount enabled (only on "buy now" and only if you pay with pay pal).
    * The cash back takes 60 days because they don't want you to buy something and then just return it.
    * If you don't find the ebay link you can just search for any other item and once you are inside ebay use their search.
    96 Soarer GT - Gone
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Where did you purchase them from?
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    Quote Originally Posted by Dimcorner View Post
    Remove TORX?
    Remove 18mm bolt?
    remove the two 21mm bolts on the back of the caliper and it will come right off
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Sep 27 2007
    Columbia, SC
    Quote Originally Posted by ///M3 TO S4 View Post
    21mm? I thought they were 18mm...
    96 Soarer GT - Gone
    Sep 27 2007
    Columbia, SC
    Quote Originally Posted by s42k5b View Post
    brakemotive76 on Ebay Powerstop rotors with pads (pads have sensors also... or at least there is a cable coming out of them).
    I'll let you know how the install goes, I don't forsee any problems considering that sizes are pretty standard. I have used PowerStop rotors before on the RX7 and didn't have a problem with em, figure I try them out since my OEM rotors are fairly scored.
    96 Soarer GT - Gone
    May 31 2008
    New York
    Very Nice..keep us posted with feedback
    Aug 10 2007
    Any pictures? What kind of pads are they?
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    get a deep impact quality socket, the snadard thin wall will break, trust me I have cracked them befor, Good luck bro
    Senior Member Three Rings lonestar22's Avatar
    Aug 19 2008
    DFW
    all i have to say is good luck removing the front caliper. you WILL NEED an impact gun if your cars anything like mine
    SGM 330i 6MT/RD PLATE LIGHTS/RES DELETE
    STAGE 1 B5 S4, CAN YOU SAY SLAMMED?
    Sep 27 2007
    Columbia, SC
    Awww dang it! Ok I better go back and get the right one...
    Pads are powerstop pads. Figure they are at least OEM quality.
    Will post pics up today.
    96 Soarer GT - Gone
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    I have heard of this before. It only shows 25% back for me though.
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Sep 27 2007
    Columbia, SC
    Rotors.
    Brake pads.
    Only problem was that the plugs for the front pads were not the same.
    After a little splicing of wires it was fine (no brake light inside).
    Rotor comparison.
    All done!
    Rear rotors were 10.2lbs.
    96 Soarer GT - Gone
    Senior Member Three Rings Muck_and_Grind's Avatar
    Jun 09 2008
    2001.5 Audi S4 (on stands), 1989 Grand Wagoneer, 2007 B9 Tribeca
    Lodi
    how hard was it to splice the wires? on a 1 to 10 scale?
    Sep 27 2007
    Columbia, SC
    .5 maybe? 2 wires and just either solder them together (this would make it a 1 I guess) or use crimps (wires are small so get small crimps). Tape them up with electrical tape and you are good to go.
    96 Soarer GT - Gone
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    THis is a great thread because my brakes are in dire need of replacement.
    Question I have is any brake squeeling? And it seams they are supposed to be low dust pads, but keep us informed if they do have any brake dust.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Sep 27 2007
    Columbia, SC
    Last night did the break in procedure.
    - At first I heard scraping from pad scraping the rotor when not braking. After the break in procedure everything was good.
    - I don't feel that they stop quicker, but what I do notice is they feel more responsive. Hard to put into words, but they feel more linear than the OEM ones. I will report on dusting as soon as I drive it some more (I work from home, so not much driving for me).
    I will also try stomping on the brakes to see if they actually do stop faster.
    96 Soarer GT - Gone
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Hey Dim, what break-in procedure are you using? I just got a new set of PBR pads myself and want to make sure I 'set' them properly.
    Thanks.
    Sep 27 2007
    Columbia, SC
    Quote Originally Posted by CONTROL ONE View Post
    Thanks.
    I just followed what the directions said.
    1. 3x 35mph - 5mph @ 50% braking power. Don't let brakes cool down and don't stop (do them back to back).
    2. Cool down (drive around a little without heavy braking)
    3. 3x 45/50mph - 10mph @ 75% braking power. Don't let brakes cool down and don't stop.
    4. Cool down brakes
    5. Your done.
    96 Soarer GT - Gone
