Results 1 to 2 of 2
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    Arrow What is this gearbox issue?
    Ok well its not super bad, but on my 97 a4 2.8 122k miles w/ stock clutch that i know is going to be going sooner or later. It is sometimes harder then normal to get the shifter into first and sometimes second gear.
    It almost sometimes goes half way and need to push it a little more to get it all the way in the gear. Also. When my shifter is in gear, it has some play, i can move the shifter left and right probably 1/4 of an inch and depending on how much on and off i am with the gas with the car in a steady gear, the shifter will move around slightly. Is this a throwout bearing? Should i just not worry about it since ill be doing a clutch in less then a year anyway, or maybe sooner if it goes out...
    i dont feel like changing my fluid unless i NEED to. thanks guys.
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    Re: What is this gearbox issue?
    Its the actaul bushings in the shifter that allow the side to side and back and forth movement your talking about while in gear. YOu can buy a bushing kit and do it oyurself in less then an hour. Me personally I like a lil play so I let mine be.
