    Registered Member Two Rings 04-A4's Avatar
    May 26 2008
    Leesburg,VA
    W/M Injection Kit on a N/A motor
    Whats everyones opinion on this. I've read that it a good gain of power even with the N/A motor. let me know what you guys think.
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    Re: W/M Injection Kit on a N/A motor
    I don't think it would hurt.. You can still advance your timing and see a bump in power.
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Not really worth it on a N/A engine. You will see like 10 crank hp.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Aug 26 2005
    Quote Originally Posted by 04-A4 View Post
    The only way this would be worth the trouble, is to allow the ignition timing to be advanced a lot. The thing is, the timing can't be advanced the same globally, using a fixed adaptation channel offset value, the ECU maps would need to be changed to advance the timing based on rpm, specific load, (BMEP) as allowed in conderation of the amout of water/meth in percent of fuel flow injection rate. There won't be any power gain unless the ignition timing is advanced to compensate for the side effects of the water/meth injection.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    It'll at least help keep the motor clean.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
