well my car hasnt been running great lately.
just got back from a garage after an intake mani leak test. no leaks, that's good.
didn't check if I have a bent fuel rail because my mechanic refuses to spray starter fluid on the injectors.
so on the way home, CEL blinks like crazy. no blown CPs here!!!!!
I just let the car cruise, luckily, I was very close home. the A/F is dead on 18
here are the codes I got and I am so pissed after dumping all the $$$ and here is what I get in return.
19 Faults Found:
16826 - EVAP Emission Control Sys: Small Leak
P0442 - 001 - Upper Limit Exceeded
17511 - Oxygen (Lambda) Sensor Heating: B1 S1: Performance too Low
P1103 - 008 - Implausible Signal - Intermittent
17550 - Load Calculation Cross Check: Lower Limit Exceeded
P1142 - 002 - Lower Limit Exceeded - Intermittent
16485 - Mass Air Flow Sensor (G70): Implausible Signal
P0101 - 008 - Implausible Signal - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded
16685 - Cylinder 1 Misfire Detected
P0301 - 002 - Lower Limit Exceeded - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 002 - Lower Limit Exceeded - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 002 - Lower Limit Exceeded - Intermittent
17537 - Fuel Trim: Bank 2 (Mult): System too Rich
P1129 - 002 - Lower Limit Exceeded
17535 - Fuel Trim: Bank 1 (Mult): System too Rich
P1127 - 002 - Lower Limit Exceeded - Intermittent
17547 - Fuel Trim: Bank 2 (Add): System too Rich
P1139 - 002 - Lower Limit Exceeded - Intermittent
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 002 - Lower Limit Exceeded - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 008 - Implausible Signal
16689 - Cylinder 5 Misfire Detected
P0305 - 001 - Upper Limit Exceeded
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 008 - Implausible Signal - Intermittent
16690 - Cylinder 6 Misfire Detected
P0306 - 001 - Upper Limit Exceeded
17548 - Oxygen (Lambda) Sensor: B2 S2: Internal Resistance too High
P1140 - 008 - Implausible Signal - Intermittent
16544 - Oxygen (Lambda) Sensor B2 S2: No Activity
P0160 - 004 - No Signal/Communication - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 001 - Upper Limit Exceeded
