Results 1 to 9 of 9
    Senior Member Two Rings 4R!NGS's Avatar
    May 11 2008
    Nassau, Bahamas
    white a4 with tire shine sling
    after i wash my car i am 100% guaranteed that my car will be dirty within 10minutes of driving. this is because when i put one coat of tire shine on my tires the stuff flys off and goes on the side of my car. is there any tire shine that will stop this or at least not leave as much spray?
    Senior Member Three Rings fatty1.8t's Avatar
    Mar 04 2007
    2003 A4 1.8t
    Birmingham, Alabama
    Re: white a4 with tire shine sling
    dont put so much on. ive had the same bottle of tire shine for about a year now and ive only used1/2 of it and i wash the car at least every other week, usually every sunday
    AZ Schmeckles Member #1. OG status in this bitch
    APR 1+, custom exhaust with magnaflow 14851s, intake, test pipe, sub, koni coils, rs4 sway, 17'' oettinger re's
    Veteran Member Four Rings pyro's Avatar
    Mar 18 2007
    '05 A4
    Tampa, FL
    and if you aren't already, stick with a gel instead of a spray, it tends to stay on longer and adhere to the tire better. I usually don't drive my car for a bit after i wash it, a) so i can show it off outside, and b) so all the water dries up and the tire gel sticks to the tire better in the sun.
    Veteran Member Four Rings AudiA4Style's Avatar
    Feb 24 2004
    B8.5 S4 l 75 CB550 Cafe Racer
    I like Adam's VRT. Not too shinny, just perfect.
    Senior Member Two Rings DEB5S4's Avatar
    Jun 21 2008
    Stamford, CT
    Meguiars tire gel, been using it for almost 3 years now and have had absolutely zero problems with slinging
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    vrt, great product, no sling
    Jul 20 2004
    I third VRT - great product but it leaves more of a satin finish instead of "wet"
    Registered Member Two Rings
    Jun 18 2008
    Davis and San Francisco, CA
    the gel ones are oil based which don't stick very well so they sling. get a water based one
    Stage 3 Forum Advertiser Four Rings DetailersDomain's Avatar
    Feb 24 2004
    if you don't mind me asking what tire dressing are you using that is slinging so much.
    also you might want to wipe the excess off or go easier on it.
