Results 1 to 31 of 31
    Feb 19 2008
    V8 powa!
    Texas
    Looking into getting suspension for my B6. Opinions and feedback wanted.
    Wanted to see what suspension you guys have and what is your personal experience with it pros and cons.
    Thanks.
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    Re: Looking into getting suspension for my B6. Opinions and feedback wanted.
    H&R coilovers: Pros: Reasonable price, drop like a rock, pretty good ride. Cons: I'm happy with them, can't think of any cons.. Oh I guess they don't say StaSiS on them, that is about it for me.
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Quote Originally Posted by ieatfishburitos View Post
    stasis uses the koni kit, not HR ;)
    Jan 10 2007
    Earth
    Hey ngng, what I was getting at is I wish I had 3k to buy a nice Stasis set, not that they are the same :)
    2013 White 911 4S
    2005 Moro Blue S4
    Veteran Member Four Rings S4DTM's Avatar
    May 26 2008
    '12 TTRS, '01 S4 Full 3.0L Racecar
    Moraga, CA
    H&R tend to get loose after a few thousand miles. If you can afford it, go with the STaSIS Ohlin SLs...by far the best on the market for everyday drivers! Pros: Stiffer ride without the huge decrease in everyday ride quality, amazing balance at the corners, great hold through curves...etc etc etc
    Cons: You'll spend a lot more on gas due to increased driving time
    [COLOR="red"]l FRRG Northern Ring President l
    '17 Alfa Romeo Guila Quadrifoglio
    '01 S4 Racecar "Giggles" - Sponsored by 034Motorsport
    Four Rings Racing
    Gone but Never Forgotten:
    '07 S4 DTM
    ->'12 TTRS - Phantom, Titanium, CF Mirrors, Sport Exhaust, Tech, Butt Warmers, Tint and Clear Bra, APR Stage 1, 034 Midpipes, AWE Boost Gauge
    Mar 09 2005
    Santa Clara, CA
    lol, true
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    i have H&Rs.... got them put on my car a couple months back... they make a huge difference... i would recommend them!
    04' Nogaro S4 - 19" BBS RS-GTs - H&R Coilovers - Hotchkis RS4 Sways - 4500k HID fogs - JHM solid shifter trio -JHM intake manifold - JHM port matched intake spacers - JHM longtube headers - JHM tune - Fast Intentions resonated catback - Snub mount - Vag mods - hardwired V1 - Clutchmaster Stage 3 clutch & 13.5 lb flywheel - Euro B7 RS4 steering wheel - Cayenne Big Reds - stern engine mounts - Stern upper control arms - K&N panel -
    Jan 14 2008
    B8.5 S4 - 6MT Sepang/Panda
    Calgary
    KW V3's
    /Thread
    Oct 27 2008
    chesterton
    tein basics. rides awesome
    tein basic FTW
    04 Nogaro/Silver Tein-K&N-Custom Exhaust-Pioneer AVIC-D3
    Feb 26 2006
    I have Stasis Trackports, ride is not as good as stock at 25.5 fender to ground. Great on smooth roads and turns, jarring on tougher roads.
    Next time I would get a set that the rears can be adjusted without removing the subframe.
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Quote Originally Posted by dascsh View Post
    PSS can be adjusted without taking the rears out.
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    Senior Member Three Rings Rodknock's Avatar
    Jun 25 2008
    The Dirty T, WA
    What is it that you are looking to do with the car?
    Do you want to track it every weekend?
    Do you want to track it once in a while?
    Do you want to just dump it and go low?
    Jan 10 2007
    VA
    Stasis:
    Ride
    Handling
    Ease of adjusting the front.
    Ease of adjusting the rears.
    Its not a big deal if you set it and forget it. But it was a huge PITA just trying to get them where I wanted.
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by b6onboost View Post
    Stasis:
    Ride
    Handling
    stasis has 4 ssuspensions avail (1 is not in production anymore)....streetsport, tracksport, SL, motorsports. they all are different
    Veteran Member Four Rings bsrpilot44's Avatar
    Feb 25 2007
    B7 S4
    So.Cal
    I <3 my STaSIS Motorsports!
    You can adjust them anyway you want.
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    You can also go the spring/shock route if you don't want to spend the extra money on coilovers. Springs are limited to H&R and Vogtlands. Shocks are only Koni's. You can also upgrade your sway bars with either H&R or Hotchkis (H-sports). I believe Neuspeed has sway bars too.
    /S4
    AWE l Koni l H&R l Hotchkis l VMR l LEDs by fly
    Feb 19 2008
    V8 powa!
    Texas
    Thanks guys. Keep it coming.
    Active Member Two Rings mutau's Avatar
    Sep 19 2008
    05 B6 S4/ Stage IV 05 STi
    Gig Harbor, WA
    Quote Originally Posted by FastB7S4 View Post
    which has a lower and more even drop, H&R or Vogtlands? Can you getaway with the stock S4 shocks?
    Deactivated Four Rings
    Apr 13 2008
    Bayern
    ^^vogts are a slightly lower drop. you can do stock shocks, but him^ and i are both running koni yellows with h&r springs.
    Mar 01 2008
    Quote Originally Posted by mutau View Post
    Not sure about the Vogtlands, but the H&R drop is perfect, for me at least. It is not too low that I have to worry about clearance in the winter and yet there is almost no gap. As far as shocks, the ride with stock shocks will be slightly harsher and a little bouncy. Obviously, if the stock shock is relatively new with low mile, it will handle the lower height better than a shock with say 40k+ miles. The shocks will also blow sooner so you will end up having to replace them earlier. Might as well spend the cash and get the shocks installed at the same time so you won't have to install twice (same procedure for installing springs).
    Here's a side shot of my car so you can see the drop. Sorry it's a rolling shot, but it's the only side shot I have.
    /S4
    Senior Member Two Rings darbyfam's Avatar
    Dec 18 2005
    New Orleans, LA
    Stasis Motorsports here with no issues at all. The best suspension I have ever owned (I have previously owned Bilstein, Koni, KW, Neuspeed, Ground Control, and Hypercoil)
    The rear is a bit low, even raised all the way, but I have no rubbing or scraping issues.
    **2020 Audi Q8 Prestige, 034 Stage 1 ECU and TCU tunes, RFX11 22x10 wheels, APR Intake, Maxton front lip.
    **2018 Audi S4 Prestige, 034 Stage 2, ECS High Flow Cat, AWE Touring Exhaust, ECS Turbo Inlet, ECS Tuning Intake, EMD Lowering Springs, Avant Garde wheels.
    Mar 01 2008
    Quote Originally Posted by darbyfam View Post
    Baller!
    /S4
    Jul 21 2008
    1997 Porsche 993TT, 2004 Sportsmobile, 1989 Mercedes 560SL, 2018 Macan GTS, 1984 BMW K100 Cafe Racer
    what's the install price range look like for coilovers?
    Apr 13 2008
    Bayern
    ^ really varies on the shop. i've been quoted 500-800 + the 80-100 for the alignment.
    a dealer will say 1.5 hours per corner. some say 2.
    Mar 01 2008
    yeah, it's not cheap.
    /S4
    Senior Member Two Rings XwalkerX's Avatar
    Dec 04 2007
    2005 s4 avant
    tuffalo, NY
    Quote Originally Posted by b spot View Post
    KW V3's
    /Thread
    couldnt agree more.
    soooo happy with mine...
    2004 Audi A4 Ultrasport [daily]
    2001 911 Turbo [fast]
    2005 Triumph Speed Triple [faster]
    1995 BMW M3 [sold]
    2005 Audi S4 avant [sold]
    Jun 11 2008
    2008 M3 DCT Gintani SC
    los angeles
    got stasis sl's ...speechless
    08 M3 DCT - Gintani Supercharged / Akrapovic Exhaust / Brembo BBK / KW V3 / HRE P43 / 3F Engineering Spoiler - Lip - Diffuser
    Mar 09 2005
    Santa Clara, CA
    i'll give you some feedback on the motorsports next week
    Apr 27 2004
    2018 GTS Cab, 2020 AMG A35, 2021 XC40 PLUS parking lift
    IMO, its worth considering Startup Racing GT coils assuming you aren't a track rat and have a budget ...
    Need a hotel in Ottawa? Try Albert@Bay or Best Western Plus Ottawa Downtown
    PM me for AZ discounts !
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Previous rides: B5 A4, B6 A4 Avant, B7 S4 Avant, B7 RS4, TTS, B8 A4, S3, 2019 Targa
    Jan 24 2008
    West Coast
    Quote Originally Posted by ALWAYS4UDI View Post
    Had a quote for $200 - so I think you can get less. Depends on where you buy it. Some performance shops will help you out if you order through them - that is if they're an authorized retailer.
    Moderator
    Veteran Member Four Rings oatzel's Avatar
    Jun 02 2004
    LA
    i'm very happy with my vogtland coilovers
    Current: '14 allroad, Premium +, Sport, Black on Black, H&R c/o, Magnaflow exhaust, Hotchkis swaybars, Neuspeed Gunmetal RSe102, CR-15
    '19 s4, P+, Quantum Grey on Black
    Old: '12 4dr GTI Autobahn, Black on Black
    07 s4 avant, ibis, stasis exhaust, vogtland c/o, h-sport rs4 sways, vmr gunmetal v710s, 50/35% tint
    09 A4 2.0t
    03 a4 3.0qms
    00 1.8TQ
