Results 1 to 13 of 13
    Senior Member Three Rings 4 black rings's Avatar
    Mar 11 2008
    West Menlo, California
    Changed battery and now key fob doesn't lock my car.
    I just changed my car battery and now the key fob will not lock, unlock or open the trunk. Any suggestion on how to fix this. Thanks
    Senior Member Three Rings CapstoneJHS's Avatar
    Nov 12 2006
    '06 A4 2.0T Quattro
    Marysville, OH
    Re: Changed battery and now key fob doesn't lock my car.
    Have you used your key to crank your car since you changed the battery?
    Active Member One Ring bourne13's Avatar
    Mar 29 2008
    Asheville, NC
    Check in your user manual, there is a simple way to fix it, I remember having to do it after my stereo was installed and the battery was DC'd for a while. If you don't have your manual, I will check mine and post how to fix it (would do it now, but don't have the manual close).
    Nov 12 2006
    '06 A4 2.0T Quattro
    Marysville, OH
    Quote Originally Posted by bourne13 View Post
    Yea, I think you just have to use your key in the ignition. Crank the car, etc. and it'll reprogram your key fob to work. You have to do this when you replace the key fob battery too.
    Senior Member Three Rings edwardabodnar's Avatar
    Mar 08 2008
    Miami
    Just happened to me....All you have to do is insert the key in the trunk key hole and turn it, Presto!
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Quote Originally Posted by CapstoneJHS View Post
    That should do it...
    It also applies, when u change the battery of your key fob, u have to do that otherwise it wont work...
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    1.) Put Key in ignition
    2.) Turn to Run
    3.) Hold down the unlock button for at least 5 seconds (while key is in ignition tunred to run)
    4.) Take Key out and test locks.
    This is the process for syncing the key to the car.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Jun 02 2008
    Greece
    Well mine doesnt even need 5 seconds...It does this at once...But yeah thats the process...
    Jun 05 2007
    Syracuse, NY
    I'm having the same problem now and none of these techniques works.
    I didn't change any batteries and the fobs are still transmitting (I checked this with a spectrum analyzer).
    Is it possible that the receiver side is kaput?
    Veteran Member Four Rings kurupt_hawaiian's Avatar
    Oct 13 2007
    2017 Toyota Tacoma TRD Off-road
    Waianae, Originally Molokai
    Quote Originally Posted by davis449 View Post
    2.) Turn to Run
    I know this works because i did this many times to my car, i disconnected my battery several times changing my audio stuff... you also have to reset your automatic windows.
    Mar 12 2008
    New York
    It works. Mine intermitely goes out.
    Turn to run-------hold unlock for 10 sec-----------try it.
    Senior Member Two Rings gervi's Avatar
    Nov 20 2007
    2006 Audi A4 2.0T
    Winnipeg, Canada
    There's a longer process in the Owners Manual. The above steps are only part of it. You have to choose which memory location to store to.
    Veteran Member Three Rings Scrwedtxboy31's Avatar
    Oct 19 2008
    2004 A4 1.8TQM (6sp)
    VA
    2.) Turn to Run
    This works, thank you so much!
