Results 1 to 30 of 30
    Oct 03 2008
    93 White NX2000, 2005.5 B7
    Lancaster, PA
    K&N filter equivalent for my carbonio
    Is there one out there? The one that came from carbonio is crappy crappy crappy. Thanks in advance.
    joshua
    Veteran Member Four Rings NorcalPB's Avatar
    Jul 16 2008
    Supercharged M3...sold/ Titanium B7 A4
    San Francisco
    Re: K&N filter equivalent for my carbonio
    K&N RU-3580!
    Been rockin it for about a month now with the stock heatshield.
    Oct 03 2008
    Lancaster, PA
    will that fit with the carbonio?
    Jul 16 2008
    San Francisco
    Probably, I mean its only 5 inches long. I think its smaller than the evoms intake and the housing size for the evoms and carbonio look about the same size so I'm gonna have to go with ya.
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    anyone know if there's a replacement for the evoms filter? mine's getting a bit dirty and i want to replace it soon
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    What's wrong with the Carbonio?
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Senior Member Three Rings Allan T's Avatar
    Sep 28 2006
    Audi a4 b7 2.0 Tfsi quattro avant sline
    Sweden
    I haven't had any problems with my Carbonio
    Mod list = To long to write.
    http://www.garaget.org/?car=118660
    Senior Member Two Rings coolguy32's Avatar
    Aug 29 2008
    Rancho Cucamonga,California
    Quote Originally Posted by NorcalPB View Post
    K&N RU-3580!
    how did you use the stock heatshield bro??? i wanted to use the k&n filter, but when i pulled off the stock box, it was completely exposed to the exhaust! talk about heat soak!!!! any info would be great! thanks
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Quote Originally Posted by supamannn99 View Post
    evoms is a cone filter, right? if i'm not mistaken, these are meant to be washed, oiled, and reused.
    you should be able to get the K&N recharge kit, it comes with degreaser and oil.
    Oct 03 2008
    Lancaster, PA
    I'm gonna get that K&N filter and clamp it to the other side of the MAF inside the carbonio box. That carbonio filter just seems so cheap. I've never seen a foam filter before. I think it'll be better for the system. We'll see though.
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    Quote Originally Posted by NothingBUTasian View Post
    Carbonio Filter should be fine, I thought it looked pretty quality when I installed it compared to just a reg. K&N CONE. I know you most likely can replace anyt of the cone filters from the various intakes, just gotta get the right size K&N
    Try to Clean it tho, most people dont need to replaces cone filters after just a small amount of use.
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    AMSOIL uses foam air filters, and swears by their performance over the traditional paper and "mesh" k&n style filters. Their studies show that they have the same flow rate of air that passes through, yet theirs provide better filtration. Basically, if you put a k&n filter next to an amsoil filter and put them side by side up to a light, the light would pass through the k&n and not through the amsoil. Their argument is that with light shining through so easily on the k&n, dirt and other small particles can also pass through the filter, which would be harmful to your engine.
    Personally, i'm indifferent. I've been happy with k&n with all of my cars in the past. In fact, i think that most amsoil pushers are kinda creepy and cult-like. I haven't seen the carbonio filter yet, please explain why it's "crappy"? or is this just your opinion?
    Oct 03 2008
    Lancaster, PA
    honestly, I just took out my maf and also looked in my turbo intake pipe and it's really dirty. I cleaned the maf and the turbo pipe and hopefully it'll stay clean. I guess from my past experiences with cone filters, it just looks better quality then that foam one.
    Nov 24 2007
    Tromsoe, Norway
    Anyone else with the same experiance with the carbonio?
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    hrm... dirty is bad... how long have you had your intake? is your filter oiled?
    Oct 03 2008
    Lancaster, PA
    I just bought the car two weekends ago. The car already had intake, tp, exhaust and apr stage 2 so I'm not sure how long the intake has been on there. I was under the impression that the carbonio foam filter did not require any oil? Is this a misconception? I just put on forge dv, ecs snub and a home made intake pipe. I've never seen the carbonio before so I took it apart to see how it works and also to put my intake pipe on and that's when I saw almost an oily type sludge in the maf and by the turbo inlet. I cleaned both with MAF cleaner and put the new intake pipe on. I'm sure the K&N filter will be fine, but I just thought the carbonio foam filter looked a bit cheap. Thats just my opinion though. There is no proof of how that oil got in there or if the carbonio filter really is letting in dirt. I don't drive the car often because I travel so much. I think I put 200 miles on it in the last 2 weeks. I'll check again in a few hundred miles to see how the intake pipe and maf look like.
    Joshua
    Jul 21 2004
    South Florida
    The gauze filters will let in just as much dirt if not more then the foam ones Carbonio uses
    2018 Audi S5
    Gone-
    Jul 16 2008
    San Francisco
    Quote Originally Posted by coolguy32 View Post
    With the sotck heat shield the short ram doesn't nearly get as hot, and its free .
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Joshua
    my understanding is that both foam and mesh filters should be lightly oiled. the key word is lightly oiled. the last thing you want is dirty oil all over your MAF.
    dirt and other small particles will stick to the oil as they pass through the filter, and ultimately get trapped in the filter. without the oil, particles can pass right through.
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    I,ve used the stock heat shield as well
    ( I also purchased two from EVOMS for the future )
    works fine
    Veteran Member Three Rings Subaru71's Avatar
    Jan 15 2008
    2010 DGM Impreza WRX
    Chino Hills, CA
    I had the exact same experience today as the other guy on here.. I've had my carbonio less than 10k miles.. only drive in los angeles suburbs.. very clean, no dirt road driving or anything. Inside of my turbo is filthy as well as inside maf pipe... fine dirt everywhere.. I would replace the carbonio filter as soon as you can.. this is crap.. I'm just not going to drive my car today until I get the replacement.
    2008 Phantom Black TQM
    Jan 15 2008
    Chino Hills, CA
    also, as far as K&N filters, these 2 would work better with carbonio, I ordered one, but I measured with my carbonio and it should fit perfectly.
    RC-9910
    RX-4120-1
    Veteran Member Four Rings ggg20t's Avatar
    Sep 18 2008
    Pittsburgh, PA
    Hey Subaru - does the RX-4120-1 filter fit on the other side of the carbonio heat shield? If you think about it, i thought there was a special bolt for the Carbonio filter... how does this even go on -- on the other side of the MAF inside the heatshield?
    i have been trying to figure this out forever.
    Jan 15 2008
    Chino Hills, CA
    for cone filters, just slip them onto the maf housing and clamp them.
    to OP, I bought the RU-whatever filter, 2 of them. They DO NOT FIT CARBONIO, I have the other one for sale if you want it, it does however fit perfectly with the stock intake hose and heatshield, as the other person had tried it, may work with evoms or other intakes as well.
    Jan 22 2009
    Mini Van
    F-burg VA
    Quote Originally Posted by p1nk50ck View Post
    I think Photons are smaller than dirt...lol
    Here is a graph from http://www.audizine.com/forum/showth...+Stock+air+box
    Carbonio vs. the oem air box plus K&N this is not HP, its airflow. Assuming more air=more power....then the Carbonio should make more power. Since we don't have a graph providing power, it could me a minor increase.
    You have to ask yourself. $379.00 vs. $49.99. Unless Carbonio produces an actual data showing superior HP and TQ gains over the K&N, the CAI looks like a waste of $.
    Just my thoughts...there are way too many CAI threads so i apologize for digressing
    07 A4
    Senior Member Two Rings kitae80325's Avatar
    Mar 31 2008
    07 a4 2.0t, 07 VW 2.5 Jetta
    pasadena, ca
    i had k&n panel filter b4 installing carboni....for perf. wise k&n i really felt more push at the very high rpm...carbonio dat push feel disappeared all u get is woooshh sound...
    Mar 31 2008
    pasadena, ca
    i installed my carbonio bout month ago....should i change the cone filter to k&n????
    Deactivated Three Rings
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Quote Originally Posted by vagebadger View Post
    ...You have to ask yourself. $379.00 vs. $49.99. Unless Carbonio produces an actual data showing superior HP and TQ gains over the K&N, the CAI looks like a waste of $.
    Exactly my thoughts. Any difference between the two would hardly be discernible in real world driving.
    Jan 15 2008
    Chino Hills, CA
    Quote Originally Posted by kitae80325 View Post
    I have the K&N filter mentioned the first few posts if you want it. I have a brand new one and an open one thats never been used but I test fitted on my carbonio.
    edit: Part # RU-3580
    Edit: just realized you have carbonio, it will not fit carbonio
    Veteran Member Three Rings baldy's Avatar
    May 11 2010
    Aprilia RSV4RF, Yamaha R1, '15 A3 TDI
    BC
    Sorry for the bump, but in case anyone was wondering K&N E-2996 fits.
    http://www.knfilters.com/search/prod...px?prod=e-2996
    C7 A6 TDI - TurboSystems 2872..Wagner IC..CGQB fuel system+MAF..RS6 intake..Eurocode sways+inserts..Eibach springs..H&R 15mm spacers..JXB support..Powerflex diff inserts..Waxedshine PPS...OE hitch..HBA retrofit
