Results 1 to 17 of 17
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    how hard is it to change fog light bulbs
    do you have to remove the bumper or can i just lift up the car and get to it
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Re: how hard is it to change fog light bulbs
    Very simple, just remove the pop off fog grill and unsrew the fog housing. And replace the H11 bulb. It should take 5 min for boths sides, it's that easy.
    Senior Member Three Rings zcrew's Avatar
    Feb 15 2007
    2014 Tacoma
    Atlanta
    yes, very easy. you need torx bits which is the only thing that could slow you down.
    Veteran Member Three Rings pa4ul's Avatar
    Mar 20 2008
    03 Audi A4 1.8T/ 72 Ford F-100
    south
    yea to pop off the grills use a flathead just look insdie and u will see there to insert and then unscrew and bam!
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    You don't necessarily need torx bits, so if you don't have them try it before buying some. Just remove the grill covering the foglight and reach your hand around back of it. You'll feel the clip holding the bulb in. Once you unsnap that rotate the bulb to get it out and vice versa on re-installation. The clips can be tricky if you have never used them before so look under your hood to see what they look like and practice on those before doing it without being able to see them.
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    cool thanks a lot guys,
    i had a quick question about something else.....i had a problem on saturday night, which i thought was the coilpack. Basically after the car shifts gears and the rpms lower, after i try to accelerate it stutters, till i really press the pedal, so i bought 2 coil packs replaced them today after i tested them, check engine light was flashin for a bit and now after i replaced them the check engine light is still on, and also the car runs the same with the same problem, any idea what else that studdering could be, F***** killin me here, i dont know what it could be, i was convinced it was the coilpack, but i guess its not
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    your car uses 4 packs, so you might just missed the bad one?
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    Quote Originally Posted by Turb_Oh_A4 View Post
    when i tested i thought it was the 2nd one from me, i tested all 4, but today i replaced that one along with the 1st one also, an after i did them, i checked all 4 and it was throwin spark on all 4 and made the clickin noise also, so it seemed fine?
    could have i missed anything?
    Jun 18 2008
    Austin, TX
    no to thread jack but what about the front blinker bulbs? (drivers side)
    how hard are they to replace?
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    shouldnt be that hard, the side markers are easy to pop of and just change it,
    but i need my previous question answered cause i dont wanna go to a mechanic if i dont have to soooooo............anyone??
    Jun 18 2008
    Austin, TX
    side markers.. it's in the headlight? lol
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Quote Originally Posted by sergeA4 View Post
    Kinda hard to find the culprit coilpack if It's not completely dead. Guessing playing musical coil pack and listening if the idle changed did not work. Do you have acess to vag-com? It will tell you on what cylinder the misfires are happening on. If I remember correctly, 95% of them time the coil pack on cylinder 3 is the first to fail...
    Did you clear the CEL by unplugging the battery?
    And when was the last time you changed the spark plugs? You could be experiencing spark plug blow out.
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    when im in front of the hood, i changed the one closest to me and the one above it, and that didnt help, i just changed the spark plugs couple weeks ago, i got the ngk idiriums, i didnt clear the code from the battery and i dont have access to a vag-com. So you think its the 3rd one from me then. maybe if the one i changed was ok i can check it by putting that one in the 3rd one.
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Not long ago me and a fellow AZiner replaced a bad coil pack (cylinder#3) and for some reason we could not make vag-com work on his car. So we unplugged the battery and the engine management fuse, waited a few minutes and reconnected the battery and problem solved.
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    Quote Originally Posted by FourRings80 View Post
    i sent you a PM
    Bklyn
    OK, so I'm reading this thread about changing fog light bulbs and it morphs into coilpacks?
    Guy, c'mon can we start a new thread for this?
    Senior Member Two Rings geoshu's Avatar
    Feb 20 2008
    '03 A4 1.8T Quattro
    Vancouver, WA
    Quote Originally Posted by Asharp27 View Post
    Too late on the thread-jacking, but just undcrew your headlight, pull it out just enough for you to reach around and pull out the clip holding in the side blinker.
