Results 1 to 10 of 10
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Winter Project questions
    My car has 137k on the odo and i just pulled the motor to do turbos and other random things. I plan on doing the head gaskets while i have the motor out since it has higher miles it could go out soon.
    My question here is, is there anything else i should do? Piston rings, rod bolts, etc or should i just leave it be? I plan on doing this slowly for the next few months so i got time.
    Thanks Guys!
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    Re: Winter Project questions
    not necessarily for winter projects, but if the timing belt needs done, do it, plus the coolant sensor by the radiator
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 10 2007
    Quote Originally Posted by AAAA View Post
    x2 That and you should be good to go.
    Jan 03 2008
    Iowa
    Timing belt and rest of the stuf was done 10k miles ago. Coolan sensor should be put on the list to do things. Thanks
    So no internals should be touched? I will be going stage 3- for a while than when i get enough money i will go full stage 3. Im also doing the clutch and clutch slave cylinder.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Motor mounts and trans mount replacement.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Oct 31 2005
    Ashburn
    Quote Originally Posted by GetAwayFromMe View Post
    Well i from what i was told, if your doing the head gaskets then timing belt has to come off, so you should aleast replaced those bolts and not re torq them. But i could be wrong
    - Instagram: @Sinister_rs5-
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    dont do the headgaskets just because you have 130k. thats absurd.
    you know how many cars ive owned with 200k-300k on original head gaskets?
    Jan 03 2008
    Iowa
    Quote Originally Posted by BurnAll4S4 View Post
    Well i figured if im gonna have the engine on an engine stand i might as well build it to last longer because i plan on running the car hard when i go stage 3. I took the whole wiring harness off and about to take the intake manifold off to do the after run pump and the spyder hose. I would hate to have to pull the engina at 160k to do the headgaskets if they go bad. I have heard of very few S4's with bad headgasket
    Jan 03 2008
    Iowa
    The only bolts that need to be replaced are head bolts. BTW. i'm also doing the chain tensioner gaskets.
    Jan 03 2008
    Iowa
    Quote Originally Posted by RolledMySTi View Post
    Motor mounts look to be in very good condition but tranny mounts are iffy.
    Thanks for all the info guys
