Results 1 to 7 of 7
    Mar 27 2008
    2008 A4 Avant SE 2.0T 6MT
    Connecticut
    Drivetrain clunk/vibration @ 4k miles
    My car is a 2008 2.0q-6MT Avant. Yesterday it started to make a faint clunking when engaging the clutch from a stop. It's gotten MUCH worse today and there is an intermittent thumping vibration that is road speed (not engine speed) related. It clunks harder off the line now too, so I don't think it is a tire.
    Any ideas what this might be? Obviously I'm going to let the dealer have at it since theres a warranty but I'm not sure it should even be driven.
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    Re: Drivetrain clunk/vibration @ 4k miles
    so the sound isn't there when you press the clutch at any time?
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Mar 27 2008
    Connecticut
    Update: Had the car towed to the dealership, they call me back a few hours later and say nothing is wrong. I took it out for a quick drive and it was fine. Would they have tightened/adjusted something without telling me?
    Veteran Member Four Rings Grishbok's Avatar
    Apr 15 2008
    Reston
    i hear a little faint clunk too, mine is brand new as well.. I figured it was normal for a cold start drivetrain engagement on a quattro.
    2008 A4 Quattro Brilliant Black
    *SOLD*
    StreetTunedTV.com
    You are violating the 3 rules of forum posting.
    1. Title thread appropriately
    2. Use the search first
    3. If you didnt find what you were looking for, its because someone else didnt follow #1.
    Senior Member Three Rings Bryson's Avatar
    Apr 07 2008
    2006 B7 A4 2.0t (not s-line)
    la quinta, California
    same for me but i have auto..took it to the dealer and they said everything was fine...figures.
    Veteran Member Three Rings gyroscope's Avatar
    Mar 19 2007
    06 A4 S-Line Quattro, 98 K1200RS, 21 GTI SE DSG
    Queens, NY/Poconos, PA
    Rear differential fluid. If the fluid somehow gets jelly like from the cold, or if the diff is low on fluid you will get that terrible sound and it gets more intense the faster you drive. The dealer usually changes the fluid and your good to go. The reason they said there is nothing wrong with your car is because AOA doesn't wan't to inform enough customers that a complaint or petition is started making it a recall item, which will intern cost them a lot of money.
    Mar 27 2008
    Connecticut
    Quote Originally Posted by gyroscope View Post
    Is this from your experience? If they are not telling people, how do you know?
