Results 1 to 15 of 15
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Resonator recommendation?
    I have APR/Billy boat, and after much annoyance, replaced the resonator with the "sport" pipe which is just a "Y" pipe. Really woke the engine up, but loud as he11 in the cabin. I want to splice in a straight through resonator to cut down on the noise... any recommendations? Anybody done this? I'd like to get a pipe and weld it in this week as I'm off to work on my race car, but can't seem to find a decent one in stainless that will clear the drive shaft.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Resonator recommendation?
    I have used Vibrant resonators in the past with much success...
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    I like vibrant I had one on my evo
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Quote Originally Posted by CO AVANT View Post
    Linky just took me to geeks. Did a keywordsearch, but that didn't get me much either. did you have just tips, or the resonator too? This one?
    http://vibrantperformance.com/catalo...cf7ce6360249c6
    thnx
    Feb 12 2004
    Everywhere
    Yes I had both on my old NS exhaust. Started with 1 12" resonator and still sounded rhaspy with testpipe, then went with another 12"....so 24" total of resonators. Also had 3.5" and 4" tips. The tips are slightly resonated but don't do much for muffling the sound. I have the regular APR exhaust now with the 3 mufflers. I might lose a tad in performance with it but it sounds perfect.
    Dec 10 2004
    R8_LS400
    Dallas, TX
    I didn't dyno the difference, but the stock APR center muffler is an incredible restriction on the exhaust. Its night and day without it. No way I'm going back to that, but its just too damn loud inside. Irony is, its not loud on the outside!
    I'll order up the quieter resonator and give it a try. Thanks.
    Feb 12 2004
    Everywhere
    Let me know how it sounds compared to the 3 muffler design. I know, I have about the most restrictive 2.5" exhaust on the market. Not worried since I don't run a cat. That is just as bad for restriction. If I end up ever going to a bigger setup in the future I'd need to go full 3" regardless...
    Dec 10 2004
    R8_LS400
    Dallas, TX
    I ordered it from amazon for $76, free ship for the quieter one....
    BTW, cat didn't make much difference in my case (I'm running creative test pipe), but it is truly amazing how crappy the APR center muffler design is. The exhaust gas hits directly into a flat plate which reflects straight back, thermally fatiguing the inlet pipe weld (hence the many breaks people are getting, including me), plus totally restricting the RPM rise. Where before, the car felt nice, but petered out long before redline, now it hits the limiter before I can get off the gas, and if the pavement is even a little bit wet it will slip all 4 tires with ease.... Major fun now!
    Feb 12 2004
    Everywhere
    maybe I should just make it an open dump so I can have the best of both worlds...
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Hmm... not a bad idea... there's even a electrically operated "Y" valve to dump... hook it up to only come on at WOT... would be cool.
    Feb 12 2004
    Everywhere
    I was thinking of adding a DMH electronic on/off cutout with the butterfly valve. The DMH has a 4 year warranty too so even if it starts to leak over time I can get it replaced for free. Only ~$200 for it too... I know other engines see big gains off these, not sure about our 1.8/2.0 BT's though...
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Well, I've had the exhaust off about 400 times now, but I took out the "Y" pipe, and spliced in the resonator tonight. Its all stainless, and I tig welded it in. It's got just a touch of boom now, but overall I think I've got the right combo. Just quiet enough, but not robbed of power like the stock APR resonator. Hopefully I won't have to mess with it for a while!
    Stage 3 Forum Advertiser Four Rings
    Apr 01 2004
    Orange County, CA
    Try the AR resonators, those have helped out a lot for the E46M3 owners looking to quiet down the beast :)
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Quote Originally Posted by Peter@VMRWheels View Post
    Thanks.. I'd have a look, but a bit late now ;) http://www.audizine.com/gallery/show...ze=big&cat=500
    The vibrant one fit just perfect too.... only about 1/2" clearance tho.
    Apr 01 2004
    Orange County, CA
    Quote Originally Posted by Spinnetti View Post
    No prob... I'm sure they all work fairly similarly from each other as long as its not made like crap :)
