Results 1 to 8 of 8
    Established Member Two Rings aleccolin's Avatar
    Feb 17 2008
    The 757
    Question Heater Core or Heater Valve?
    '01 S4, everything is normal except that I get very little heat in the cabin. It blows luke warm at best.
    I'm thinking either a mostly blocked heater core or a bad heater bypass valve. I haven't found anything on these two being a common problem, but maybe someone has had the same issue.
    Any help is appreciated.
    Established Member Two Rings hans j's Avatar
    Feb 02 2005
    TDI Syncro Westy, 2001.5 S4, Caddy, bicycle
    utah/ united states of america
    Re: Heater Core or Heater Valve?
    I have seen a few heater cores get clogged with junk. You can try flushing it out but in the end you may need a new core. We are trying a couple things at the shop to see if we can get them cleared because... basically they suck to replace.
    Feb 17 2008
    The 757
    Yeah I thought about disconnecting the lines and running some sort of solvent through on a loop, try to get most of it out, but if I'm not sure that's actually the problem I'd rather not go through all the trouble first.
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    it could be ur Thermostat or your coolant temp switch. Try changing the CTS first.
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Feb 17 2008
    The 757
    Quote Originally Posted by s42k5b View Post
    If it were my thermostat I would expect my coolant temps to be doing some weird shit. A faulty coolant temperature sensor would throw a code, or at least cause some kind of abnormality. So far everything is normal except for the lack of heat, which makes me think warm coolant is not flowing through the heater core in a normal fashion, so either malfunctioning heater valve or partially blocked core.
    2000 s4
    Fairfield, CT
    find the two hoses that go to the heater core on the fire wall. let your car warm up good and touch both of them. if they are both the same temp (to the touch) id say its something else. if one is hot and one is cooler the core could be clogged. i had a problem with a customers a4 but that flush stuff in it but ended just puting one in. and if it that. it freaking blows to do.
    i heart my s4
    Feb 17 2008
    The 757
    Quote Originally Posted by rms-s4 View Post
    Yeah I intend to do just that, haven't had the time yet. Do you recall seeing a heater valve, or does it just circulate through the heater core ALL the time?
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    mine also does not blow that hot anymore. i wille be checking it out soon. it blows luke warm, but sometimes it works good, rarely though
