Results 1 to 6 of 6
    Veteran Member Three Rings dmaize's Avatar
    Jan 26 2007
    Saint Paul
    how do i remove this antenna "avant"
    why didn't i buy a rs4 gill when they were $60
    Jan 09 2008
    88'90quattro 98'passat quattro 05. Usp a4 571whp 97 a8 00 TT 99 Passat 2.8l 5 speed 99 Passat 1.8.
    haverstraw ny
    Re: how do i remove this antenna "avant"
    you do have to take the headliner off, there is a nut inside the car holding the antenna...
    Veteran Member Three Rings jankaroni's Avatar
    Mar 01 2007
    Emerson/NJ/USA
    You can possibly just drop the back of the headliner and get to it, like the back half of it rather then dropping the whole thing. I do that a lot on cars when I have to take antennas out at my shop. Just dont bend the headliner so far that you crease it
    Aug 27 2008
    99 A4 Avant
    des moines, ia
    I was able to remove the dome lamp and gain access to the mounting bolt on my 99. the cable is still there but you might be able to loosen the bolt enough to move the antenna out of your way
    Jan 26 2007
    Saint Paul
    awesome, thank you.
    Veteran Member Four Rings Yevmeister's Avatar
    Mar 08 2008
    i haz a boat
    Wilmette/DeKalb
    what do you want vinyl over your roof ?
