The car has a rattle in the driveshaft whenever I accelerate. This is the first non-FWD car I've owned, so I figured I should check it out. I crawled under the car, and checked the shaft at the rear diff. Everything seems tight.
Then I crawled up front, and where the driveshaft attaches to the tranny, it wiggles a little and makes a nice metal-on-metal clanking. Also, there is some front-to-back movement of the shaft, and though I'm not sure if it's supposed to do that or not.
If I'm not mistaken, there should be a joint where the shaft hooks up to the tranny, correct? Is it replaceable seperately, or do I need to get a new shaft? Any other thoughts on what it might be, or do I seem on the money?
