Results 1 to 7 of 7
    Established Member Two Rings A3toB5's Avatar
    Sep 22 2008
    99 A4 1.8t & 95 Golf 2.0
    Queens Get The Money
    Transmission Bolts
    Good Morning B5 lovers..
    I figured I would ask the question here hope I get an answer before the end of the day so I won't have to go to the dealer..
    Ok here is the think I aquired a 1999 A4 with out a motor. I droped one in. I bolted up 5 bolts for the trany have 1 left thing is it doesnt' fit in the last spot. Pulled out bolt by bolt and tried it in every spot but it doesn't seem to go in all the way.. Do anyone have the part diagram of the trany to motor if not i will just have to go to the dealer and buy new bolts...
    oh this one is just FYI.. I started the car and heard a rubbing sound pulled the trany off and noticed that the bolts in the torque converter was rubbing on the sheeld between the motor and trany.. went to the dealer to buy a new plate... the gave me new bolts.. Torque patter not the 16mm hex that were in there... any noticed they changed the bolts or did the person who took out the motor put the wrong bolts back ?
    Sorry for the long post with out pics.. will post pics of my car soon...
    Veteran Member Three Rings passatkid's Avatar
    Sep 19 2006
    ND
    Re: Transmission Bolts
    First there should be more then 5 bolts.
    Sep 22 2008
    ok.. 2 thru the starter.... 3 at the bottom... 4 at the top.. and the open slot i have on the driver side by the crank sensor.. so that equals 10 ?
    Established Member Two Rings VTECCURED's Avatar
    Nov 07 2007
    98 audi a4 quattro
    PERTH AMBOY, NJ
    Quote Originally Posted by A3toB5 View Post
    thats is correct...
    i have removed the trans twice in the last two weeks .. lol
    two of those bolts have nuts on them.. the longer one with the nut goes on the pass. side, the shorter w/nut goes on the driver side.
    JOHN
    BOOSTFACTORY.NET
    Sep 22 2008
    Quote Originally Posted by VTECCURED View Post
    thats is correct...
    JOHN
    Ok so .. my question is.. the 2 bolts on the driver side.. On is the Long with the bracket that holds wires... the bolt under that one is the one I can figure out.. I have one bolt left its a bit shorter than the one with the bracket where does she go ? I might have to pull out another bolt
    Nov 07 2007
    98 audi a4 quattro
    PERTH AMBOY, NJ
    iirc...
    there should be three on the driver side.. (depends how you wanna look at it)
    on the driver side.. there is one all the way up..
    i believe it shoudl be a medium size one..
    then there is a long one.. in the middle of the driver side.
    then a short one with a nut towards the bottom ...
    JOHN ..
    im on aim.. if it will help.. easier to chat then constantly posting.
    vteckured1980
    BOOSTFACTORY.NET
    Nov 07 2007
    98 audi a4 quattro
    PERTH AMBOY, NJ
    i just tear things apart and put them back.. i really dont pay attention where things were... eventually it will go back the same way..
    But from what i recall....
    there should be three small/medium ones on top.. the driver side one goes through a bracket to hold the harness.
    on the pass. side.. there are two long ones that goes throught the starter.. another below those (long with a nut)...
    there should be three maybe four (not sure 100%) along the bottom of the trans that goes throught the oil pan..
    on the driver side.. should be a small one with a nut.. then a medium/long one above , half way up the trans (driver side) below the small that went through the bracket!
    i hope that helps a bit..
    john
    BOOSTFACTORY.NET
