Hi guys,
I'm having extremely low MAF readings on my current GT2860RS with a AEM Dryflow 3" cone filter running PES T28 software. I'm only getting about 10 psi at WOT out of my GT2860RS with no major boost leaks. Only getting 10 is more than likely being caused by my shitty Synapse wastegate but I have a Tial on the way to solve that issue.
I am having real trouble getting more power out of the setup. I checked for boost leaks and corrected one that I had but that didn't help me.
Block 032 is showing:
At Idle,-10-10% = -1.1
Partial Throttle,-10-10% = -4.6
Here is some of the information i just pulled from blocks 003 and 031 in second gear:
The PES file calls for a oem A4 MAF to be used in conjunction with a 2.75" ID housing (TT225 housing meets the requirement) and I am using that exact setup.
What are some things I can look at?
* Exhaust leaks? (I have a small leak somewhere in the exhaust)
* Get a different less restrictive air filter (AEM filters down to 1 micron)?
* Something else?
Please help me
