Results 1 to 20 of 20
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Need work done? Click here...
    Hey guys, thanks for looking...
    My names Jake, alot of you guys may already know me on here. I'm currently able to do anything automotive at the moment, due to being laid off last week. I worked at a high end european shop for several years, with the core work being Audi/VW, BMW, Mercedes and Porsche, with a hearty helping of $100k+ exotics on the side. I'll do most work for $50 per hour, which is about half of what the going shop rates are these days. I also can source parts, OEM or aftermarket (I am an affiliate for 034 and have lines for MANY others). To give you an example of what range of services I offer, take a look at the last few side jobs I've done or am doing: Coilovers on a MK3 Jetta; fabricating a downpipe, hot side intercooler pipe, turbo inlet and cat back for a big turbo B5 A4; timing belt on a MK4 GTI 1.8T; Rods on a 20th Anniversary GTI; subframe, control arm, oil pan, ball joints on a MK4 Golf; ect...
    Feel free to shoot me a pm, I will do my best to quote exactly, but it all depends on the job. I am based out of my shop in West Warwick RI, and can arrange tows for those who cannot drive the vehicle to my location. Thanks for reading.
    Regards -Jake
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Re: Need work done? Click here...
    Bump it up
    Oct 27 2007
    In the lab
    Thanks for the bump Issam!
    Jan 25 2006
    A4 2.0T
    MD
    Bump!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I clicked. I read. I can vouch for this individual.
    Jake does good work. I've worked with him in the past on his own personal A4 project. I can vouch for his quality work.
    -Doug
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    I wonder how much OP charges for proper 3.0 timing belt job on A4.
    Oct 27 2007
    In the lab
    Thanks Doug, you're the man
    Quote Originally Posted by T0M3K View Post
    Well I only do unproper jobs on 3.0's
    It's dependent on when, where and what else you want to do while I'm in there
    Sep 14 2007
    Valley Stream, NY
    Quote Originally Posted by 317ssayzarc View Post
    There is a special tool needed for that and only few can brag that they spent money on it (I personally never seen one). I just need TB, water pump and associated service. As for when and where, no clue, once I get killer deal or have too much time on my hands.
    Oct 27 2007
    In the lab
    I have done several without the cam lock tool, although my old shop had one, we didn't always use it... It's really not needed...
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    How much to change the rear main seal on a b5 s4?
    the homebrew'd s4
    Oct 27 2007
    In the lab
    Quote Originally Posted by Overboostin View Post
    550 if I can get it in there without dropping the pan, if I can't, we'll see... Thats labor only, not sure how much those seals are, but on the 2.7T I have on the engine stand, it looks like an expensive piece...
    Veteran Member Three Rings B501S4's Avatar
    Sep 09 2007
    01.5 B5S4 Stg III RS6's Built Longblock, Cherokee Classic 4x4
    Raleigh, NC
    i was looking into doing my downpipes and possibly straight pipes after that i would be interested in a quote maybe you could help me out. looking to gut mine and put back. its an 01.5 s4 and im fairly close by
    Active Member Four Rings
    Dec 11 2006
    Boston
    Quote Originally Posted by B501S4 View Post
    That is a very good choice! I ran straight pipes (from the turbo-back). I am sure Jake could definitely handle that.
    Stage 3+ RS6's
    Oct 27 2007
    In the lab
    Yea that would be well under an hours drive from the Sub Base for you
    Would you want me to eliminate the mufflers/resonators or build a complete catback?
    Sep 09 2007
    Raleigh, NC
    pretty much elimiate mufflers and resinators perhaps a true dual custom catback with just the final real muffler that would be great
    Oct 27 2007
    In the lab
    Shoot me a pm with your number, lets go from there
    Sep 09 2007
    Raleigh, NC
    PM'd
    Oct 27 2007
    In the lab
    I will call you tommorrow
    Sep 09 2007
    Raleigh, NC
    liar!!!! na im kidding i never got a call though but its staight just hit me up whenever you can i am in no rush
    Oct 27 2007
    In the lab
    I called and didn't leave a voicemail, I'll get back to you again, kinda busy today
