Results 1 to 21 of 21
    Veteran Member Three Rings 08lichmanj's Avatar
    Nov 18 2006
    PA
    How much was Revo Stage II Programming?
    Like the title states how much did you pay? I'm thinking of getting a testpipe but want to know how much i need to spend before hand. TIA
    2006 A4 2.0t Quattro 6 Speed
    Tein Basics-20% tint-18x8 Privat Reserv-VMR Testpipe-Revo Tuned Stage 2
    DUH! an Audi
    los angeles, CA
    Re: How much was Revo Stage II Programming?
    its retail +50 bucks, if you have revo now, you pay 50 bucks for stage two...maybe if you get lucky they will not charge you. Go to your revo tuner and get it done, huge difference!
    Senior Member Three Rings jrok24k's Avatar
    Feb 19 2008
    B7 A4
    yep stage 1 is 499 and stage 2 is 550 so if you go to your revo dealer and upgrade to stage 2 it should only be 50
    Established Member Two Rings CardNation's Avatar
    May 12 2008
    north pole
    Does the stage II software add anything other then turning off the CEL after adding a TP?
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    It usually comes with a bit more boost.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Nov 18 2006
    PA
    nice! thanks guys. i was reading the gti page for a price and i thought it was like 550 just for stage 2 haha. 50 bucks is a done deal.
    DUH! an Audi
    los angeles, CA
    it gives you a tad more boost, but mostly the air/fuel ratio is increased. The good thing about stage 2, it does whatever it does and you are still running 6-2-9, well at least I am running that. The base setting still runs on stage 2, but you just get the added benefits!
    -randy
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    not that im arguing with anyone, but i would like to see someone from revo actually explain more about "stage II". How could it have 'more boost' if the settings are the same as stage I?
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Jul 20 2008
    Chicago
    Quote Originally Posted by RedS-line View Post
    From my perspective, REVO software is calling for an X-multiple of boost over stock where the stock turbo can barely keep up before petering off at higher rpm. With a larger turbo, it is applying that multiple to the larger boost and air/fuel volume flow. Provided you have the other upgrades needed for Stage2 or Stage3, then you subsequently will get the power gains expected from a big turbo. Or, perhaps I have been woefully misinformed to which you can disregard my input.
    Aug 08 2008
    2017 Q5
    Houston, TX
    as for my input, i have none. but this is interesting stuff.
    DUH! an Audi
    los angeles, CA
    here is my noob understanding, contact revo for the precise explanation. Stage two is adjusting to the extra air flow and in return gives you more boost, etc. Stage 2 parameters are different than stage one, the way (I guess) revo designed stages was to make it as less complicated for the driver to adjust when using the selecter, so stage 2 for example, 6-2-9 (which I have) is not the same as 6-2-9 for stage one, because stage 2 is taking into account and optimizing your test pipe or hfc. It goes into more details, but that is the fundamentals...Correct me if I am wrong
    bmeister, I dont think revo or chips in general are multiplying x boost or other parameters in excess that would create long turn affect to the engine. What they do is just give you more safe boost, which the stock turbo can handle (10 psi stock, chips 18-20lbs). I havent read or seen anyone who has needed a new fuel pump based on just regular chipping or minor modifications (intake, fmic). Now, if you do more crazy things like water meth or highly over boosting your car, than for sure you will be maxing out your turbo and fuel capabilities. And of course a bigger turbo will give you better output and way better gains will be given, but I doubt you will still run the basic tuning on a bigger turbo (I mean this without any sarcasm).
    -randy
    Mar 19 2008
    i would like to see actual maps comparing stage 1 to stage 2. perhaps the hp and torque curves are moved a bit with a couple extra peak hp, but i still cant imagine 6-2-9 of stage 2 producing more boost than 7-2-9 of stage 1. correct me if im wrong
    2019 S5 BO.SS
    2009 R8 6 Volt :)
    DUH! an Audi
    los angeles, CA
    ^^me too, but I am not the person who has those answers...that would be something directed at revo....I think they used to be around here? Else contact them via phone.
    Or ask your local revo tuner, I barley have graphs of my car lol
    Jul 28 2008
    2008 A4 S-Line, 2005 BMW M3
    New Jersey
    Sorry for the noob question but what exact does 6-2-9 and 7-2-9 actually mean?
    Jul 20 2008
    Chicago
    Quote Originally Posted by Cirlincione623 View Post
    Typically the REVO tuners and customers refer to the settings of the REVO tune by the Boost-Timing-Fuel parameters set when you get your ECM flashed. So, the 6-2-9 referred to is: Boost=6, Timing=2, Fuel=9.
    These are set by your tuner or, if you purchase the REVO SelectPlus as I have done, can be set your self as you make additional performance modifications to your engine. In other words, you won't have to go back to the tuner and pay for an upgrade as you go along the road to higher performance mods.
    The boost setting can be 0-9, with 5-7 meant for 93 octane and a stock turbo; higher settings can be made when you have an upgraded intake/intercooler, larger turbo and better exhaust. The timing setting for 93 octane is usually 3-6 depending on the quality of fuel in your area, or higher if you run 100 octane fuel. Finally, the fuel setting leans the mixture as you go from 0 to 9 with 9 being the leanest for performance. In Chicago, I run 7-5-5 on 93 octane, stock turbo. When it gets hot --- then I switch to 6-4-5 for best hot weather performance with lousy summer-blend gas.
    Why not just notch all the settings to the max on a stock engine you might ask? Because the stock turbo, 91 or 93 octane, stock intercooler and stock exhaust cannot meet the demands being requested by the high settings. Subsequently, you'd get the onset of detonation whereby the ECM "pulls back" (over-corrects) boost, timing, fuel requests by the REVO software. That over-correction results in less power under those stock components than if you used the recommended REVO performance settings for stock.
    Oct 14 2006
    MK6 Jetta
    South,FL
    I would lean out fuel a bit there, 4 on fuel puts allot of pressure in the cam follower.
    -EI AL CAI.
    -Driver Mod.
    DUH! an Audi
    los angeles, CA
    Also to add to what bmeister stated, if you max out a setting 9-9-9, your car will learn to block out that setting, so for instance you run iunno 8-7-9 and your car pulls a lot of timing, over time your car will reject that program and say if you went big turbo your car might not want to give you 8-7-9 no more because it has been blocking it.
    Our cars are very smart, from what I have been told!
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Quote Originally Posted by HID View Post
    HID what were you running when you blew up your fuel pump?
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Jul 20 2008
    Chicago
    Please explain how? That is a mechanical unit that has a fixed pressure. No matter what the engine intake requires for fuel, it is simply pounding away to maintain 1600 psi.
    When the engine is taking in more fuel due to a bigger turbo and chipped ECM, the volume needed cannot keep up (fuel cut outs). Leaning the Fuel setting (i.e. 7-9 range) a lot may help prevent fuel cuts, but it should have no effect on the mechanical pump running off the cam unless, somehow, the lack of a load due to the depleted pressurization causes some float in the pump accelerating wear. Is that what you meant?
    Jun 15 2009
    2007 Audi A4
    IL
    I had fuil cut out on my 2007 Audi A4 6 speed m/t q, i bought upgrade pump from www.kmdtuning.com
    APR wants 1099.00$ for there upgrade pump, you could get the same resluts on the same upgrade from KMD. If anyone needs it get it from there. The car improved like crazy, no more cut out's, the car is running alot better, if noone has this upgrade done to there cars, i would recomend it, unreal preformance on STAGE 2 Revo chip:)
    Apr 09 2009
    Holly Springs, NC
    What all is needed for the stage 2 software?
    Some people say HFC/testpipe only, some people say full exhaust, can someone clearify?
    Thanks,
