Results 1 to 16 of 16
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    HELP NEEDED! Ecode FMIC Install
    I cant get the drivers side in. I trimed the bumper and followed ecode's install to the T. What am i missing....?
    Heres some pics. I know i could trim it more and get it to fit but the point is i shouldn't have to.
    Here's the install instructions: http://www.ecodetuning.com/fmic.pdf
    Nov 25 2007
    Re: HELP NEEDED! Ecode FMIC Install
    Some one...
    Oct 29 2005
    10speed
    San Francisco, CA
    push the pipe as far into the hose as you can, looks like you just need to do some trial and error
    - Clint
    Senior Member Two Rings ScaryGary's Avatar
    Nov 29 2007
    Silver 04 Audi A4 1.8T 6-Speed
    Sacramento
    The front-on picture looks as if the right side of the IC is lower than the left side. Make sure the IC is level, and it looks like it might move the tubing out of the way slightly more.
    calm the fuck down. it's all relative.
    Nov 25 2007
    Quote Originally Posted by ScaryGary View Post
    Have a look at the third pic.
    Its tilted down like that right now because the pipe that comes out the right side needs to fit under the fog light housing in the bumper. If it wasn't tilted the bumper would be much worse.
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    i trimmed a little from my bumper and kept the middle connection so I could meaunver it into place
    Nov 25 2007
    Ok ill try those later tonight, at school right now.
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    loosen all your connections, wiggle, push, repeat. Start from the ic core.
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    do it over and over again till you get it right. you dont need to hack it that bad with ECODE FMIC... you should be ok... dont worry. i know how it is though. pain in the ass!
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    That should help the most. Both pipes should be touching each other inside the hose.
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    yeah typically it's just that the pipes aren't close enough to eachother in the sleeves, or the pipes are just too long in general and need hack-sawing (my racetec and gtrs)
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Nov 25 2007
    Ya, hopefully it's just that easy.
    Pulling the bumper off for the first time was a PITA.
    I was starting to get frustrated, that and a few beers in.
    Veteran Member Four Rings eurogruppe's Avatar
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    its not an ultrasport is it? If so then im pretty sure the front bumper is a little shorter and uses a thinner rebar than the other b6's
    21' Audi RS6 | E30 M3 | 996 Turbo | Corrado SLC | IG: @stevedavid993
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by eurogruppe View Post
    did you see the pics?
    - Clint
    Nov 25 2007
    Got it all done
    All i had to do was trim the IC outlet pipe a little (3 inches to be exact). The bumper slid right on with out any problems.
    I think i striped both the bolts for the bumper crossmember tho.
    Feb 12 2004
    Everywhere
    I had to do the same thing when installing the 1st version back in 04. Mine was the turbo outlet pipe though. My bumper never lined up perfect for some reason (shifted L->R) which might have been the reason, Glad you got it figured out...
