Results 1 to 22 of 22
Thread: Blowoff valve
    Oct 26 2008
    Delaware
    Blowoff valve
    Can any one suggest the best blowoff valve for 07 2.0t
    Active Member Four Rings Goped220's Avatar
    Feb 16 2006
    2023 Audi S4, 2023 Audi A4 & 2016 Subaru Crosstrek
    NY/FL
    Re: Blowoff valve
    Forge
    Previous:
    2006 Audi A4 Stage 3 6-Spd, 2011 Audi S4 6-Spd, 2016 Audi S4 6-Spd, 2017 Audi A4 6-Spd Stage 2, 2019 Audi S4 Stage 1, 2019 Benz E450 Stage 1, 2015 STI, 2013 370Z, 2013 Benz GLK, 2014 F-150 FX-4, 2020 Lexus GS350 F-Sport
    Jul 28 2008
    2008 A4 S-Line, 2005 BMW M3
    New Jersey
    Re: Blowoff valve
    Well, I don't think there are a lot out there for our cars so you don't really have a big selection. lol...I have the Forge diverter valve with spacer and its sounds flawless. Its pretty loud, you can here it coming from down the road sometimes. I'm really happy with it. I highly recommend the forge =]
    Veteran Member Four Rings viperdsa's Avatar
    Aug 28 2007
    Angry Gerbils
    west of the equator
    Re: Blowoff valve
    Forge DV
    '06 Dolphin Gray A4 2.0T
    Motoza Tuned EFR
    Veteran Member Four Rings whitevdub's Avatar
    May 10 2007
    Long island
    Re: Blowoff valve
    my car decided to make its own bov noise that i can control
    Senior Member Three Rings jrok24k's Avatar
    Feb 19 2008
    B7 A4
    Re: Blowoff valve
    i have the KMD BOV
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    Re: Blowoff valve
    our cars dont have bov's they have Dv's....forge i would recommend
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    May 20 2004
    More cars
    Never Land Ranch
    Re: Blowoff valve
    I don't have a BOV or Forge DV and my car with just the Carbonio intake makes that noise....
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Veteran Member Three Rings jimmya4's Avatar
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    Re: Blowoff valve
    i decided to get a forge spacer on stock dv for 40 bucks off a friend. more of a head turner than any intake in my opinion. some people complain that the blow off sound is too lengthy but i like it still and its been a few weeks.
    2005.5 Quartz grey A4 Quattro 6mt/ REVO stage II
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Re: Blowoff valve
    Cuz you are a new person... you should understand that our cars use diverter valves and not blow off valves.
    Read this article thoroughly: http://jsalmi.com/bov/
    I recommend you use a DV made by AWE or Forge. AWE is probably the better deal. You can't go wrong either way. BOV FTL!
    Oct 26 2008
    Delaware
    Re: Blowoff valve
    Thanks For the replys!!!!!
    DUH! an Audi
    los angeles, CA
    Re: Blowoff valve
    forge!
    Senior Member Three Rings Allan T's Avatar
    Sep 28 2006
    Audi a4 b7 2.0 Tfsi quattro avant sline
    Sweden
    Re: Blowoff valve
    What about the new Hks dv.
    Mod list = To long to write.
    http://www.garaget.org/?car=118660
    Veteran Member Three Rings Parts4Euro.com's Avatar
    Sep 16 2008
    Michigan
    Re: Blowoff valve
    We have these ones currently ON SALE.
    EVOMS 2.0T Billet Recirculation Valve Kit
    FREE SHIPPING WORLD WIDE!!
    PLEASE ORDER HERE
    IN STOCK READY TO GO!!
    Evolution MotorSports has engineered a new performance and maintenance component for the VW/Audi 2.0T Motors. The EVOMS 2.0T Boost Recirculation Valve (BRV) Kit is a direct replacement for the OEM unit and features an improved and more efficient design. Our BRV is CNC machined from aircraft grade 6061-T6 aluminum, hard anodized and utilizes military spec Vitonâ„¢ O-rings. The EVOMS CAD designed BRV employs the same operating principal from our 1.8T piston diverter valve which has been successfully operating for nearly 8 years. Combining our successful design principles, stringent theoretical computer and real world testing, the EVOMS 2.0T BRV eliminates issues of boost leaks and diaphragm sticking and deterioration that is consistent with the OEM valve in higher than stock horsepower applications.
    The EVOMS BRV employs a mechanical, boost referenced, operation over the factory electromagnetic operation. By using vacuum/boost pressure over the OEM electronic control, alleviates communication delay and increases reliability and performance. High levels of heat from the valves direct mounting to the turbo and the inconsistency of operation lead to the factory valve’s premature demise. With our billet construction and mechanical operation, it can handle significantly more heat and power. These valves were originally designed for the Porsche 997TT and have been tested to 750+ horsepower with perfect success. They have been extensively tested on the 2.0T motors from stock to 340+ horsepower with unparallel results. Our OEM approach extensive, kit includes everything needed to convert a 2.0T to a better performing and more reliable performance machine.
    EVOMS 2.0T Billet Recirculation Valve Kit (BRV) Kit Includes:
    • 1 EVOMS Billet Boost Recirculation Valve Assembly
    • 1 EVOMS Relocation Bracket for Factory Electronic Actuator
    • 1 EVOMS Billet Cap to Seal off the Factory Electronic Actuator
    • 1 Section of OEM grade hard black Vacuum Line
    • 1 EVOMS Custom Silicone T-Hose to Tap Into the Manifold Vacuum/Pressure Line
    • All Necessary Mounting Hardware, clamps, assembly grease, zip ties, instructions
    Forge Motorsport Piston Diverter Valve for VAG 2.0 FSiT
    PLEASE ORDER HERE IN STOCK READY TO GO!!
    Please See below for more information from Forge Motorsport's Website
    We’re proud to announce another industry first for the Volkswagen and Audi tuning market from Forge Motorsport!
    Many owners of any VAG vehicle equipped with the all new 2.0T FSI engine, have unfortunately discovered, that the OEM electronically controlled bypass valves, which bolts directly to the compressor cover of the turbocharger, have their limitations. If you are running increased boost pressures, after a software remap (chip), or the OEM valve is being subjected to high temperatures, the lifespan of the unit is significantly reduced. Even without any modifications taking place to the vehicle at all, this OEM valve has been shown to fail over time and it’s boost holding capacity also leaves some room for improvement.
    We now have the world’s first fully engineered solution offering both significantly improved reliability as well as valve related boost response. Our valve and installation kit replaces the original unit with a pressure/vacuum operated piston valve that still also retains the desirable OEM ECU control over valve actuation. This product has been thoroughly designed and tested with the expressed intent of offering improved valve response and maintaining ECU control while resulting in absolutely NO fault codes, NO check engine lights, and no adverse effects of any kind. All of the necessary components and detailed instructions are included and everything is designed to make installation as simple as possible.
    This product is applicable for all of the following 2.0 FSiT applications:
    VW Golf MK5 GTI/Jetta GLI, VW Eos, VW Passat (B6)
    Audi A3, Audi TT Audi A4 (B7)
    SEAT Leon
    Skoda Octavia
    For all vehicles where the OEM valve is mounted remotely (8P Audi S3, MK5 Golf Edition 30 and the Seat Leon Cupra), please see product reference FMFSITVR. )
    Forge Motorsport Atmospheric Blow Off spacer for VAG 2.0 FSiT
    PLEASE ORDER HERE
    Yet another first for the Volkswagen and Audi Tuning Market from Forge ! With the introduction of the VAG 2.0 litre FSi Turbo Engine, and the procurement of our own development/project car, we have developed a Patented Atmospheric Blow-Off adapter specifically designed to fit this application. Simple in execution, yet offering the desirable atmospheric blow-off valve sound, this product has been designed to be fully compatible with the Bosch ME9 engine management systems employed on the following vehicles: Audi A3 2.0T FSI Audi B7 A4 2.0T FSI Volkswagen MK5 Golf GTI/Jetta GLI 2.0T FSI. Please note: This valve fits the turbocharger mounted solenoid valves and will not fit the latest 2007 on, remote mounted solenoid valves, on the S3, 30th Edition Golf and Leon Cupra R, which have a different bolt pattern. For these vehicles please see FMFSITR
    Parts4Euro.com NEW WEBSITE!!
    Email [email protected]
    Subscribe our Newsletter
    Follow Us on Twitter
    Join Our Facebook Page
    Your best source for high quality European parts & accessories for your VW, Audi, BMW, New Mini Cooper & Porsche
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Re: Blowoff valve
    Forge
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Re: Blowoff valve
    Forge+Intake FTW
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Senior Member Three Rings tdavit's Avatar
    Aug 27 2005
    CT, FL
    Re: Blowoff valve
    awe cheapest and best
    Jun 02 2008
    Greece
    Re: Blowoff valve
    ^^And unless I am very much mistaken some have failed...
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    Re: Blowoff valve
    you should be able to get a hybrid BOV / DV (at least we can in our B6's), so you'll still get the BOV sound. can't remember the brands off hand though, just do a search in the B6 forum and you'll find a wealth of info.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Aug 27 2005
    CT, FL
    Re: Blowoff valve
    [QUOTE=Doctor;3007560]^^And unless I am very much mistaken some have failed...[/QUOTE
    I could be wrong but I have not heard of any failing. I did have two different forge ones and they threw cel codes all the time i just went back to the stock before i went to awe, it works fine for me.
    Jun 02 2008
    Greece
    Re: Blowoff valve
    I on the other hand have never ever heard of someone facing problem of any kind with a Forge DV...Never ever...Weird...
    Jul 28 2008
    New Jersey
    Re: Blowoff valve
    I have had the forge dv and spacer since waterfest never threw any cels no problems
