We have 52 K on our 2006 A3, 2.0 L FSI, and the check engine light just came on. I used the fault code detectpr at a local parts store, and it says we have a P0302 error, which means "cylinder misfire detected in the second cylinder".
Anyone had this before? If you have, did replacing the spark plugs solve the problem? Finally, how do you get to the spark plugs? I assume I have to pull off the black plastic engine cover... not sure how to do that either, but I haven't spent much time trying to figure it out yet.
Thanks in advance!
