So I recently installed my 2.5" DP to compliment my Tru Dual and I just want to know more about how these DPs work; in general.
I already know that downpipes allow more airflow to flow smoothly from my engine to my exhaust, and also creating faster turbo spool-up. It also "reduces" the heat build-up on my k03s....
My questions are:
1. Now that I have a faster spool up, at what RPM do my K03s spool at? Is still @ 1850?
2. With just ECU mod, my peak boost would be around 4500, and would taper off soon after. With DPs + Exhaust, at what RPMs would I see peak boost?
2a. Would my boost constantly stay level @ 15psi well after 5K or would I just taper off as I did with just chip?
3. When driving today, I noticed that I would be able to stay in 1st, 2nd and 3rd longer than I did (during DD I would usually shift between 2100 and 2700rpms, upon ), why is that? (if this Q ties in with #1, tell me)
3a. I also noticed that when I hit 3K-3200rpms, my boost guage tells me I'm at 0psi, before if/when I hit 3K-3200rpms, I would boost ~5psi, why is that? (Again, if this Q ties in with #1, tell me)
4. Importantly, now with DPs on, how much more strain is put on my K03s?
On to off-topic questions...
1. If I buy the ECS dual clamps designed for pipes ranging from 53-60.5mm, it would clamp and offer a tight seal on my 2.25" exhaust, yes?
2. Same as above question but for my 2.5" DPs to be used with 65mm clamp?
Anywho...
In the next week or so, I'm going to put my stock exhaust and stock DPs in the classified section. I think I'm going to gut my stock DPs. Just wanted to let you gents(and ladies) know if you're looking for a stock exhaust and DPs
