Results 1 to 9 of 9
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Running Rich... keeps coming back
    I have tried everything on my car to get it running without any CEL and to stop getting it into going in safe mode..
    List of things i've changed or done:
    1) Inspected at an Indy, fixed injector leak, fixed any boost leaks, changed MAF.
    Still kept jumping into Safe Mode.. soo
    2) Changed the flash from Tech9 Stage 1+ to Unitronic Stage 2 (also 1+)
    Still didnt help, although I did spike and hold more boost.
    3) Changed both O2 sensors yesterday
    Car is running better, more audible, and it just went back into safe mode and VAG says its running rich
    I have no idea what to do from now, I really thought that the O2 Sensors would have fixed it, but it didnt and now im clueless
    Edit: 1 Fault Found:
    17535 - Fuel Trim: Bank 1 (Mult): System too Rich
    P1127 - 002 - Lower Limit Exceeded
    Someone help me out !
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Running Rich... keeps coming back
    Coolant temp sensor on the back of the head? Do you have any logs? Make sure all 3 of your eng. managment fuses are good, don't ask me how I know.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    I have no idea about the coolant temp sensor..how do I know if its bad? My temp sensor reads normal (cold at first, but warms and stays in the middle)
    I dont have any logs...I could try to get some for you if needed.. but which blocks ?
    And are the engine management fuses located the same place as all the other normal fuses (left side of the steering wheel) ?
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Up up and away.
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Quote Originally Posted by GtiRSmiley View Post
    Yes the engine management fuses are same places as the others. From memory, one of them is #32 if I remember correctly, I once removed it by mistake instead of the radio fuse, they are on the same line. So read the fuse map and check all the engine related fuses.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Checked all the fuses..they seem fine
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    I forgot to post the fault code..so I updated it in the first post
    Oldguy..where art thou!
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    A multiplicative (mult) trim DTC indicates that your ECU is having to adjust the fuel trim across the whole RPM range. Usually this is either caused by a faulty MAF sensor or a boost leak. You indicated that you already replaced the MAF and checked for boost leaks. You might want to have the shop recheck. If the shop just did a visual check for split/cracked hoses and didn't pressurize the system they may not have found the problem. With a boost leak the MAF "sees" a larger volume of air than is actually going into your manifold. The ECU is applying fuel at that rate (which is too high for the actual air volume) and the front Oxygen sensor recognizes the rich condition.
    Good luck!
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Good luck!
    Thanks. I'm currently busy with school, but I'll be taking it to a garage within the week..
    However I did manage to get a log of block 031 as somebody wanted on AW..I dont know much about logs so I just uploaded the raw file without any converting (as i understand, to get the actual numbers I would have to multiply by something)
    http://www.mediafire.com/download.php?gwwgnmjvmjo
    Hope this helps with anything
