Results 1 to 3 of 3
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    maintenance help
    ok so i just got my car home. And i pulled it into the garage to check it out and i noticed that the coolant is low, brake fluid is low, and the oil is low. The other thing is that the dipstick handle is broken as well.
    First what are the best to go with as far as brake fluid, coolant, and oil are concerned? Also does anyone know how much a dipstick will run me?
    Veteran Member Three Rings A4p's Avatar
    Mar 06 2006
    Audi 1.8TQM6 S-line USP 2004
    Sweden
    Re: maintenance help
    go with Motul 5w40 oil, brake fluid and coolant just go to you local audi dealer
    USP CLUB MEMBER 861
    Rev0 stage I file - 300+ bosch injector - OFE SS - APR Snub mount - Nitrogen - RS4 Swaybar - K&N air filter - **-
    Veteran Member Three Rings Monkey77's Avatar
    Oct 30 2007
    2005 Audi A4, Tiptronic.
    new jersey
    dipstick should be about 9-12 bucks....you can probably find one at ecstuning.com
    " You can't be lucky all the time, but you can be smart everyday."
