Results 1 to 11 of 11
    Veteran Member Four Rings Groove1797's Avatar
    Apr 08 2004
    Your mom on a unicycle
    Eating Cheese Curds
    Adj control arms (pre-order)
    4Runner, Rs5 and Alfa Guilia QV
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Re: Adj control arms (pre-order)
    NP. I should check mine to see how they are doing. Last I looked the arms look fine but I have a torn CV boot. Time for some new axles, I guess.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Looks like their are out! Awesome.
    I just bought some CPP arms though.
    -Doug
    Sep 20 2006
    Baltimore
    Yeah, preorder now and they are supposed to ship in November. I got an email from PureMS about it and saw they hadn't made any announcements on the boards yet. I posted something over on AW.
    Did you get used CPP's? I thought he stopped making them some time ago.
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Any advantage to these outside of track use?
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Definitely, you can dial in an alignment for a lowered car that will allow the tires to wear evenly and track down the road as straight as an arrow...
    The only downfall I see to these is that by using the OEM rubber bushings, if you track the car, under high stress the alignment settings will not hold.
    Jan 21 2007
    "Old Yella"
    san antonio tx
    I see, these might be in my future as I plan on going lower than my H&R set-up.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by skeeball View Post
    Very slightly used. They, effectively, look brand new. Sitting in a box in my basement until I buy coil-overs next year. Bought them from a fellow AZ member a few weeks ago.
    -Doug
    Veteran Member Four Rings 3ohAvant's Avatar
    Mar 10 2004
    east bay, CA
    hmmm interesting that they would use OE rubber bushings with this kit.
    - Benny
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    The arms are coming standard with OE bushings for a couple reasons.
    1. They're cheap and keep the price of the kit down.
    2. They're readily available. No custom parts to make, no need to search the world for the right parts. Thus see #1.
    3. They work. No need to test other configurations, because we know these work exactly as they're supposed to.
    4. They're quick and easy to replace.
    5. They're quiet. No clunking, no clicking that you get from a spherical joint. They work as isolation to keep noise to a minimum.
    We will be offering a spherical joint replacement as well. Consider it an upgrade for those track guys that don't want rubber bushings. It'll be be an option in a few months.
    Polyurethane will NOT work in this application. There's too much side loading on the arms when you start adjusting the caster, and it will cause poly to fail very fast.
    Hope that answers the questions.
    Mar 10 2004
    east bay, CA
    I'll be interested to see what the price is w/ the non OE bushings. My friend is looking for something, not me. I'll send him the link, although I doubt he wants the rubber bushings.
    - Benny
