Results 1 to 26 of 26
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Today's Dynojet #'s vs. setups from the past
    First 2 graphs are today. Fully built 2008cc, 3651 cams, T25 Gt2871R .64, revo 550 file. 104oct. 25psi tapering to 22psi (turbo can spike higher than gtrs on my setup on same settings)
    3rd is on fully built 1984cc, 3651 cams, gtrs, revo 440 file, 104oct, 23psi-22psi
    4th is stock 1.8T (1784cc) engine with gtrs, 104oct, 23-22psi
    5th is Stock 1.8 with K04 on 112oct, revo, 24psi
    The #'s from the superflow dyno will be in on Monday to compare.
    Temps in the dynojet room today were ~80deg F. Car makes tons more power when it's 40deg out
    MacAuto Dynojet elevation is just under 6000ft
    #'s varied a tad from what Greg said because I was just thinking off the top of my head on the drive home when I talked to him and forgot exact #'s. I have no doubts I would put down 380+whp uncorrected on a mustang dyno at sea level in OPTIMAL conditions. When I ran down there a couple months ago my car had never run worse (totally different than on the street down there). 100+ degree in room temps. 80+deg IATs, sucking in exhaust fumes, car hiccuping and misfiring. My IAT's today were in the 25-35deg C range. Timing and fuel on at 12:5:1 MUCH BETTER!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Today's Dynojet #'s vs. setups from the past
    Great Job!
    Congrats.
    This looks great. I knew it would come out like this.
    -Doug
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Really nice #'s Jordan!! Are you happy with them? 400AWHP is just around the bend for someone, who's it gonna be?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Nice numbers Jordan, I expected you would be right around 340-350 "actual" whp. If you ever decided to come down let me know, I will line up some time on a local Dynojet that is now one of my dealers.
    IDRC is next month and Fontana will be having full weekend Street Legals in Nov/Dec.
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    very impressive numbers.
    so your motor is fully broken in ?
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Nice numbers Jordan, I expected you would be right around 340-350whp uncorrected. If you ever decided to come down let me know, I will line up some time on a local Dynojet that is now one of my dealers.
    fixed
    Jul 07 2004
    socal
    Quote Originally Posted by 400HPA4 View Post
    fixed
    LOL, I didn't know we had to put "uncorrected" after the actual whp a car makes now. I mean come on, does anyone really drive a car that makes "corrected" numbers?
    Ok I corrected my first reply. Happy now?
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    If it is good enough for the Society of Automotive Engineers...
    Jul 07 2004
    socal
    Maybe its just me, but isn't the point of getting on a dyno is to find out how much the car actual makes at that time or how much actual whp it has gained from the last time?
    Veteran Member Four Rings DenverNoob's Avatar
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    The debate over corrected vs uncorrected will always be here. Fact of the matter is in some circumstances, corrected numbers are a good means for comparison. Until one lives at high elevation, they really don't understand that. Motors that qualify for a valid correction factor, imo, are those fi cars whos setups can/will actually move more air at sea-level then at altitude. NA cars certainly qualify, as do FI cars with, say, a bt setup like mine or jordans. Why you ask? Even ill be the first to admit that my k04 turbo could not move one gram more air here vs sea-level vs the top of mount everest. It was just too small. In that case...corrected #s are silly. A bigger turbo like mine, or jordans, however, WILL and is capable of moving more air. Thus a correction factor, while not finite (and neither is anything but a true engine dyno, btw) is a good GUIDE as to what a comparable setup would make at sea level. Correction factors are supported in these cases by a number of automotive sanctioning bodies...but at the end of the day, anything that comes off of a chasis dyno is just a guide, nothing more. Please comment on the #s and quit quibbling over this stupid bs. Its impressive, end of story. Besides...I was there...it was fun! Let's no lose sight that in the end, we all do this because of the enjoyment it brings.
    USP CLUB MEMBER #26
    2019 SQ5 Prestige - 034 ECU Stage 1, TCU Stage 2
    - a few Golf Rs in-between -
    2004.5 QMT6 Ultrasport Loaded (retired)
    Jul 07 2004
    socal
    Quote Originally Posted by DenverNoob View Post
    What boost level did you run at on the dyno? I know you most likely have way more head room since the extended tip turbos have a sweet spot that is at a much higher boost level then the garrett turbos. This is why they have a better effiency at higher PR levels. Hope to see more dyno's from you pushing much higher boost levels in the future.
    Feb 12 2004
    Everywhere
    Ted's software still needs a bunch more tweaking being a new file and all. I expect him to make tons more power in the future. I just hope it doesn't become faster than mine, sorry Ted
    I am happy with my car and the power it delivers be it corrected or uncorrected #'s. The graph shows what gains were made over previous setups and how power comes on much better in the lower rpms, which I feel is very impressive. There is room to improve the timing/fuel in lower rpms to get even quicker spool, but that will take time and a software remap. There is not much else I can say. I dyno at ~6000ft. It is what it is. Peace.
    Jul 07 2004
    socal
    Quote Originally Posted by CO AVANT View Post
    I am happy with my car and the power it delivers be it corrected or uncorrected #'s. The graph shows what gains were made over previous setups which I feel are very impressive. There is not much else I can say. I dyno at ~6000ft. It is what it is. Peace.
    70.65 uncorrected whp gain since last time. Thats a good amount of power right there.
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    I ran at 22psi...pretty much the same as Jordan mentioned above...my software needs quite a bit of work It was installed on thurs...and needs a bit of tweaking for sure...its a completely custom file and needs to be worked out...overall I was actually really happy with my results given that I had all of 6 total hours of development into the new file when i hopped on the dyno.
    As far as turbo sweet-spot goes...the s256 doesnt really "light up" until 25ish PSI...so some work to be done there as well.
    I will post existing #s when the charts arrive. Lots of work to be done but a great day overall. One thing that became dreadfully apparent...my intercoolers are toast. Good thing winter is just around the corner!
    USP CLUB MEMBER #26
    Jul 07 2004
    socal
    Yeah it doesn't really come to life till 25psi, but they really like 30+psi. The 300's really like to run at 40+psi.
    Friends of mine run their S372's at 50psi.
    To give you a good idea.
    So at 6000 ft pushing 22psi your really looking at a 2.9 Pressure Ratio. At 30psi you would be around 3.6 PR. Even at that boost level you still have some head room left while the GT2871r will be way out of its effiency map.
    This is exactly one of the reasons I want to try out the HTA35r because plenty of people are seeing really good numbers when pushing 40-44psi with them and the standard GT35r just doesn't do well at those boost levels. We are also looking at the HTA30 for another car. But this all depends on if/when we become a FP dealer.
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    That is precisely the reason we picked this turbo...up here in no-mans-land,it was the perfect choice for my build and daily drivability.
    USP CLUB MEMBER #26
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    nice
    Some fast things and some slow things
    ~Josh~
    Jan 25 2006
    A4 2.0T
    MD
    hmmmmmmmmmmmmmmm
    HTA 35R huh?
    Like this:
    Mar 21 2006
    Lakeland, FL.
    Boing!
    I'm back bitches!
    Jul 07 2004
    socal
    yes like that and like the one that my friend has been running for some time in his EVO8 which is the car I ran 11.3 at 124 mph pushing 23psi in the USCC.
    Jan 25 2006
    A4 2.0T
    MD
    It runs nicely on my car... me likey....
    Jun 29 2007
    Raleigh, NC
    Quote Originally Posted by dirtybrd View Post
    Boing!
    ditto
    does spurt of the moment apply now chris?
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Feb 12 2004
    Everywhere
    I always knew that a full T25 2871R setup would yield much better power and quicker ramping up over the more choked up elim setup. There is no disputing results when they are conducted like I did it.
    Feb 12 2004
    Everywhere
    I should have overlayed PTwiggins APR 3+ setup on 104oct/file with stock 1.8T engine. We dyno'd on the same day a couple years ago (run file 009 on graph for me). He ran 328whp, 321wtq sae corrected (stock apr3+ on 104). With my 2.0L and 2871R I made 91whp and 76wtq more corrected (120chp). Even that right there is a big jump from your stock apr3+ setup on race gas.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    We will get that comparison when my car and Greg's are done.
    APR 3+ with APR software on a 1.8L -vs- 2.0L with 2871R and 3651s on a custom tune
    -Doug
    Jan 25 2006
    A4 2.0T
    MD
    Good work Jordan -- Hope you are happy with the power. It seems to be holding together for you nicely..
