Results 1 to 9 of 9
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    Weird Brake light issue...
    Both my brake lights blew today on the left side (there are two of them) and I found this odd that they blew at the same time. Nonetheless I went to pick up some P21W bulbs from CAP which surprisingly they had them in stock. I replaced the original's and it still doesnt work. The fuse doesnt make sense because it controls all brake lights and the right side and the center brake lights work. Anyone know what might be the deal here?
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Veteran Member Three Rings likewater's Avatar
    Sep 18 2006
    2012 Honda Pilot, 2005 F150 FX4
    So Cal
    Re: Weird Brake light issue...
    This is going to sound stupid but check to make sure you are putting the bulbs in the correct place. I made this mistake. When you take more than one bulb out at a time, if you don't put them back into the proper slots, they won't work. I haven't been inside the light assembly for a while, but if I remember correctly there is an open slot that is not used. I accidentally put one of the new bulbs into that slot and of course it didn't work. After I got them in the right place, everything worked perfectly.
    Current - 2011 B8 S4 DSG Presitge - APR Stg 1 | RS4 Grill | Magnaflow Xpipe and Mufflers | K&N | Apikol Rear Diff Mount (Race)| H&R OE Sports | Avant Garde M310 19X9.5 ET 40
    SOLD - 2005 B6 S4 6MT with many mods.
    May 30 2007
    MA
    Quote Originally Posted by likewater View Post
    When I removed it there were definitely bulbs in every slot. I have no idea here. Connections look good. Im at a loss...
    2014 R8 V10 - Gated
    Veteran Member Three Rings Chapunki's Avatar
    Sep 05 2008
    AZ
    I am having brake light problems as well, my DIS will give me a warning that the right rear brake light is out but it will go away after I turn off the car, only happens once in a while, what could it be?
    I've noticed the right side is definitely dimmer...
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Is it just brake light that is out or all of them out too?
    Maybe check the connection in the back and make sure it didn't get loose.
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    May 30 2007
    MA
    Quote Originally Posted by 40valve View Post
    Its just the brake light that is out as the parking light and flashers work. Ugh I hate wiring!
    2014 R8 V10 - Gated
    Sep 18 2006
    So Cal
    There is also a bulb in the left assembly that is a "rear fog" bulb. It's the one on the far right in the assembly. Again, I would check to make sure all the "correct" bulbs are in the "correct" spots.
    Mar 24 2008
    khgkhg
    Did you happen to figure it out?
    Asking because I just got a warning that left license plate light is out.
    I went and pulled it out and the bulb looks fine. Swapped it with the right one and it works on the right side and the one from the right doesn't work on the left. So I know it's not the bulb. I'm thinking it's the same issue that you are having.
    Sorry don't mean to thread-jack, just wanted to let you know that you are not crazy and that something else can be going wrong
    |^^^^^^^^^^^\||____
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    it could be the harness. this has been known to be an issue with the B6. it can lead to your battery getting drained. this cannot be diagnosed via VAG.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
