Results 1 to 3 of 3
    Registered Member Two Rings MidwestA4's Avatar
    Oct 04 2007
    The Palm, Michigan
    Face-Lift Sunroof/Headliner in Pre Face-Lift
    I need to replace my sunroof motor/slider and found a local parting out a 99 A4.
    I know that the sunroof assembly will fit my 98 but is there anything special needed to install the headliner into my car?
    - 98.5 A4 Quattro
    Veteran Member Four Rings goody6691's Avatar
    Feb 23 2005
    Elkton Md, B.A.T certified
    Re: Face-Lift Sunroof/Headliner in Pre Face-Lift
    it wont fit. i tried to put an s4 interior in my 98.5. the headliner wont fit, nor will the pillars.
    too much shit to list
    Dave
    it runs bitches..............im back
    98.5,Brilliant Yellow, Audi ,A4,Quattro, 2.0, je, eagle, cat cams, tial, hta3076r, tap 630, CCW Classics, Falken,SPA, Autopower, Sparco
    Veteran Member Four Rings Tifun's Avatar
    Jun 21 2007
    99.5 A4, 08 Mazda3
    Indianapolis Indiana
    I have a 99.5 and I have older pillars in my car, including the visors, oh shit handles etc. If you do the rear pillar you need the whole thing, both the goofy L and the main pillar. I traded my middle pillars as well. Also the interior lights will have to be swapped. Basically you will need the whole setup. I have my original sunroof panel but the pull handle is older. I swapped all the gray crap out for the tan and then put suede on everything a peanut butter color.
    On a side note if the car is a 99 and not a 99.5 you shouldn't have any issues considering your car is a 98.5
    EDIT: My parts came from a 97
