Results 1 to 29 of 29
Thread: Pinch bolt!!!
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    Angry Pinch bolt!!!
    Replacing axles today and ofcourse that fucking pinch bolt is an ungodly piece of shit. I've been slaving my ass for over and hour already and poured about a can of WD40 on it but it still won't budge
    Nut came of quickly but its taking the bolt out is what i can not do. Tapping, prying, kicking, swearing and nothing, its baked inthere for good it seems...
    Any sugestions? PLEASE!!!!!
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Pinch bolt!!!
    Heat it with a torch.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Apr 23 2007
    Re: Pinch bolt!!!
    Quote Originally Posted by dirtybrd View Post
    tried... no dice...
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Mar 21 2006
    Lakeland, FL.
    Re: Pinch bolt!!!
    Did you heat the spindle to red hot? You have to heat the metal the surrounds the bolt not the bolt itself.
    I'm back bitches!
    Apr 23 2007
    Re: Pinch bolt!!!
    i did, not to red hot though. i'll try again...
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Mar 21 2006
    Lakeland, FL.
    Re: Pinch bolt!!!
    Try to keep the heat off the ball joint boots. Also, after you heat it, let it cool for about 2 mins and douce it with WD40. The heat will draw the oil in.
    I'm back bitches!
    Apr 23 2007
    Re: Pinch bolt!!!
    how long would you say i should be heating it for? i;m using mapp gas but still can't get it red hot...
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Mar 21 2006
    Lakeland, FL.
    Re: Pinch bolt!!!
    Mapp gas will take a long time is at all.
    I'm back bitches!
    Apr 23 2007
    Re: Pinch bolt!!!
    i thought it was hotter then propain? i have propain too, should i use that instead?
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Mar 21 2006
    Lakeland, FL.
    Re: Pinch bolt!!!
    You need acetylene.
    I'm back bitches!
    Apr 23 2007
    Re: Pinch bolt!!!
    You need acetylene.
    what's that and where do i get it?
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Mar 21 2006
    Lakeland, FL.
    Re: Pinch bolt!!!
    I't s the kind of touches that uses 2 tanks, the other oxygen.
    I'm back bitches!
    Apr 23 2007
    Re: Pinch bolt!!!
    oh i see. i know what you;re talking about now. well, i'll go to SEARS tomorrow and pick up and air hammer, will see if that helps, i'll let it soak real good in WD40 overnight, if that don't work, its drilling time...
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Jun 13 2008
    02 b5.5
    Re: Pinch bolt!!!
    never touched the pinch bolt when doing my axles
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Pinch bolt!!!
    Torch is the way to go man. I got a gorillar bar with a socket on the end and even BROKE the snap on socket. I used an acetylene torch and nearly friend my control arms in the process, but that seems like the only way. Heat it up for 30-60secs then hit it with a punch
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Apr 23 2007
    Re: Pinch bolt!!!
    Quote Originally Posted by swaigo View Post
    How the heck did manage to get the axle out, i tried and i tried, but there's just now enough room. Bentley does say to only undo the control arms if you can't get the axle out, so i guess there's a way... i wonder if there's a trick to it, but i just don't see it.
    Share why don't you.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Apr 23 2007
    Re: Pinch bolt!!!
    Quote Originally Posted by biketsai View Post
    I wish i had that torch but the only one i have is mapp/propaine. I'll see about maybe getting one tomorrow as well.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Apr 23 2007
    Re: Pinch bolt!!!
    i'm officially screwed... The head snapped, tried drilling and f-up the housing. So now i'm looking at replacing both upper control arms as well as the wheel bearing housing... all because of one fucken bolt...
    can someone tell me the good place to buy the arms and housing please?
    thanks
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: Pinch bolt!!!
    holy hell that thing sounds like a bitch....
    Are you referring to the bolt in the middle of the hub? (The one needed to undo when removing the CV axle?)
    -Sami-
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    Re: Pinch bolt!!!
    Dude I feel for you. Every time I try to fix something or mod something on my car I run into the "fucking bolt" syndrome. I get so pissed and distraught sometimes I want to go ape shit on the car with a hammer! Just know that if you step away, find someone that knows a trick, it will take them 5 minutes and make you feel better! I had a stripped lug that was on tighter then a nats vagina! Shit would not come off. I hammered on a smaller socket and that didn't work. Took it to Just Tires down the road, they charged me 5 bucks, had it of in 30 seconds.
    My rule of thumb on the Bitch Bolts, use your brain not your muscle!
    Good luck!
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Senior Member Two Rings KevinA41.8T's Avatar
    Nov 30 2005
    CONNECTICUT
    Re: Pinch bolt!!!
    u only need to remove the rear lower curved control arm from the upright. dont even have to pull the caliper off. thats it. dont know why people mess with the pinch bolt.
    2000 S4 IMOLA - CCW CLASSICS 18X9 18X10 - STASSIS TRACKSPORTS 700/800 - ASP DTS - STERN MOUNTS - 034 DP'S - ASP TRU DUAL - CUSTOM INTAKE/CATCH CAN - VAST METH - AEM WIDEBAND - RS4 INTERCOOLERS - JFONZ TUNED
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    Re: Pinch bolt!!!
    i have always used PB blaster it eats the rust pretty sweet stuff
    Mar 21 2006
    Lakeland, FL.
    Re: Pinch bolt!!!
    Just remove the whole assembly, take it to a machine shop and have them remove it.
    I'm back bitches!
    Apr 23 2007
    Re: Pinch bolt!!!
    thanks for all the suggestions, i ended up fucking the knuckle up pretty bad with drilling and still didn't get the fucking thing out... so i just put everything back together and limped over to my buddy's shop, ended up ordering a new knuckle and both upper control arms, so half an hour $100 job turned into a week and $500. the only thing that makes me feel somewhat better that both control arms needed replacing anyway... the bottom line still, i'm pissed as a mofo... FUCK THIS GOD DAMN BOLT!!!!!!
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Re: Pinch bolt!!!
    Quote Originally Posted by alexza4 View Post
    I know what bolt your talking about it took me like 6 hours to get both out with the car on the lift. The trick is air hammer and cutting up the bolt in sections. But if the head is not cut off already take a air wrench/gun on one side and a aim hammer on the other. I tried heating it red hot, I tried drilling it out but the it became impacted and couldn't drill. So i ended taking a death grinder cutting it in sections and pushing it out with the air hammer.
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    Re: Pinch bolt!!!
    I tried to do this last friday. I ended up going in from the bottom and just squeezing the new axle in. I got this far then realised I didn't have a 12pt socket. So I took it to a local Vdub dealership and they replaced the axle for me in a hour and a half. At $68 an hour it came to $108, plus I bought the axle online for $99. I'll never replace an axle again.
    High speed Ferrari movement...
    Mar 21 2006
    Lakeland, FL.
    Re: Pinch bolt!!!
    Don't forget to apply a liberal amount of anti-sieze!
    I'm back bitches!
    Apr 23 2007
    Re: Pinch bolt!!!
    Update.
    After a horror story of doing the right side (ended up replacing the spindle and both control arms after completely f-n up it up because of that damn pinch bolt), today i did the left side.
    Took exactly one hour. This time i was going to undoo the lower control arms instead, bur didn't even had to do that. There's more space on the left side so you're able to wiggle out the axle without having to do loosen up the spindle assembly!
    So note to everyone else who will be undertaking the DIY axle replacement.
    Right side: Have to undo the control arms. DO NOT mess with the upper control arms, undo lower. Much easier.
    Left side: See above.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Feb 20 2007
    ct
    Re: Pinch bolt!!!
    Update.
    that must of been expensive, i remember pricing one out right before i got my bolt out. And yes what a PIA good thing i replaced it with a fully threaded bolt which makes it a little bit skinnier. And if i do need to replace them i can just off the head and put a bolt on the other side and pull it out like that
